Old 05-21-2002, 08:16 PM
EDurney EDurney is offline
Default P 4`s Results on the dave_c test
I know that this topic is a little bit rusty, but i wanted to know how P 4 users are doing running the Davec test.
My Pc :
Intel 845WN Mobo
P4 1,6 ghz
256 SDram pc133
Riva TNT2 Nvidia AGP
20gb 7200 rpm HD
Win 98SE
21 tracks crying all the way.
not good. can I expect more? [img]images/icons/rolleyes.gif[/img]
Pro Tools 10 / Duet 2 - Eleven Rack - Mbox 2 pro
MacBook Pro 2.2ghz Quad Core/ 8gb RAM/ 750HD
Pro Tools 9 HD / 192io / C24
Mac Pro Quad 2.66 / 8Gb Ram
Old 05-22-2002, 08:16 AM
STUDIO-DE-ARIEL STUDIO-DE-ARIEL is offline
Default Re: P 4`s Results on the dave_c test
Thats the board I have you might need another hard drive.
Mine is not built yet is yours an intel board?
Old 05-22-2002, 07:28 PM
Yeah, Intel 845WN Motherboard
What about the Hard Drive?
Thanks for posting
Old 05-22-2002, 08:53 PM
8mmOverdose 8mmOverdose is offline
Thanks for posting
<font size="2" face="Verdana, Arial">you should get better results with your OS and programs on one drive, and another drive dedicated for audio.
Old 05-22-2002, 09:04 PM
yeah, I knew that.
Thanks 8mm overdose
That`was your observation Studio de ariel??
Old 05-22-2002, 11:22 PM
Yes that characterizes all I was saying Quite well actually. Also I was wondering about the type hard drive speed.
We have the Same board so we can work on it together.
I will let you know about anything else.
Old 05-23-2002, 02:55 AM
QuikDraw's Avatar
QuikDraw QuikDraw is offline
21 tracks is not out of line for a P4 1.6 with PC133 memory. That's about all you'll get with that setup.
I get 23 tracks with my P4 1.7 with DDR memory.
Motherboard: Asus P4B266
CPU: Intel P4 1.7GHz (retail boxed)
RAM: 256MB PC2100 266MHz DDR
Video: ATI All-In-Wonder Radeon 32MB DDR OEM (Driver Ver. 4.13.9016)
ATA-66: on-board Intel chipset ATA-66/100
Promise ATA-66 PCI (PCI slot 6)
Audio: Creative SB Live! Value (PCI slot 2)
Digidesign 001 (PCI slot 4)
on-board 6 channel (disabled)
Modem: Creative Modem Blaster Flash 56 Voice (PCI slot 3)
NIC: SMC Easy Card 10/100 PCI (PCI slot 5)
Hard Drives: Maxtor 6 L040J2 - 7200 RPM - UDMA 100 - 40GB - System (master on Promise ch1)
Maxtor 5 T060H6 - 7200 RPM - UDMA 100 - 60GB - Audio (master on Promise ch2)
Other Drives: 3 1/2" Floppy
Zip 250 IDE (slave on on-board ch1)
HP CD-Writer+ 9100 (master on on-board ch2)
Toshiba DVD-ROM SD-M1612 (master on on-board ch1)
Removable IDE hard drive bay (slave on on-board ch2)
Ports: Com1, Com2 (disabled), ECP Parallel
on-board USB 1.1 (disabled)
on-board USB 2.0 (disabled)
Adaptec Duo Connect USB2.0/Firewire (PCI slot 1)
Power Supply: Enermax 350W ATX dual fan
Case Fan: Bottom Front
I'm curious what I would get with a new Northwood P4 on the new 533MHz memory bus.
Mike
-- Mike
- HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics
- Windows 11 - PT 2021.12
- PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i
- Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs
The Test Results are In!!! dougied 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-03-2008 09:05 PM
Dverb Test results? sureno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-24-2007 06:21 PM
New DaveC test results hornedrum Pro Tools M-Powered (Mac) 5 12-08-2005 03:36 PM
Why am I getting bad results on davec test? Matt Whritenour 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-26-2003 06:31 AM
ProTools 5.3.1 Test Results Bassart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-04-2002 07:39 AM
