How to insert time / insert measures, without upsetting tempo map and markers
Hello,
I have a finished session, complete with many markers and a very complicated tempo map with lots of meter and tempo changes. I need to add four measures of time IN FRONT of the whole session. How can I insert 4 measures of time in front of everything without upsetting the markers or tempo and meter changes? There must be a way to do this. Of course I cannot just slide all the regions over to the right as then everything would get out of wack. I've read through my Digi books for quite a while and still cannot seem to find the answer. Any help would be greatly appreciated, as soon as possible. Getting crushed against a deadline and unable to work until I resolve this issue. Thank you. -imp [email protected] |
Re: How to insert time / insert measures, without upsetting tempo map and markers
Just in case I was unclear above, my goal is to insert time / measures in front of the session while keeping the audio region to tempo/meter map relationship the same. I merely wish to drop an extra 4 measures of time in front of the song without disrupting anything after that point. thanks
I'm not in my studio right now, and I'm not sure I remember exactly... but if you select all the audio by dragging in the timeline then SHIFT+Click in the tempo/meter/marker timelines I think it will select each timelines contents. I would then cut and paste everything 4 bars later (I don't remember if nudging worked). I seem to have done something like this in the past but not sure about details and how I did it.
Sorry I couldn't be more help, but maybe this will get you on the right track. Good Luck.
Producer/Engineer/Drummer/Golfer I.B.S. Studios The artist formerly known as Nine Spine. |
If your session is already butted up to the front of the session start time.. then open the Session Setup Window and enter an earlier start time for your session... Hopefully you didn't have it at zero hours, minutes, etc.. then you can elect to maintain time code location and now you have space available to add more bars to the front of your session. If you did have your start time as zero.. then you'll have to make your session start time later and have PT move the session relatively.. then go back and add more space in front of the session.
As has been mentions.. you can also do some edits in the timeline as well by shift and clicking in the timeline area to include it in the edits. Renumber bars may also be useful in this situation. Rail
Insert measure -> move tempo-bpm etc. | AJF | Pro Tools 10 | 5 | 06-01-2012 10:35 PM |
Insert Time with "Spotted" Tempo? | ChrisSimon | Pro Tools TDM Systems (Mac) | 4 | 08-03-2009 05:59 PM |
Insert Track ? Markers in a Bounce File | ohok | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-06-2007 04:59 PM |
BDF insert - can't change tempo | habernacks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-27-2006 11:52 AM |
Insert Measures | MusicGuy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 05-09-2004 01:13 PM |
