Midi Latency With Pro Tols 7.4cs5
Hi, when I record things using my midi controller I get midi latency with 7.4. I mean when I play it and record it, it sound fine but when I replay my recorded session the notes are cut off prematurely and the timing is way off. I read about correcting using samples and midi event but that seems annoying. Is there another way to fix this?
And which controller specifically?
The platform and OS questions that Stig asked are very important. If you are on Windows and using a Multi-core processor, there is a very important Windows update that you need.
hi guys I run windows vista with a intel t2450 dual core processor, and use an m-audio axiom 61 midi controller. Which update are you referring to? I use the xpand virtual instruments package.
n/m guys I got it corrected with the technical support.
You might want to post the solution so that others that end up with the same or similar problem will know what to do.
Then again, you might not.
AIR Instrument Expansion Pack 2.0/Pro Tols 11 | martinaston | Pro Tools 11 | 2 | 08-18-2013 02:29 AM |
7.4 to 7.4cs5 = more CPU usage | PhilBuckle | Pro Tools TDM Systems (Mac) | 3 | 07-31-2008 04:54 PM |
Amek tac scorpion with Pro tols | sukks2bu | Pro Tools TDM Systems (Mac) | 5 | 05-04-2005 06:40 PM |
6.4cs5? | ejwells | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-01-2004 05:55 AM |
Pro Tols 5.x for mbox user | ilgato76 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-23-2004 05:33 AM |
