Playback volume much louder than recording volume
When punching in vocals, the part of the vocals playing during the lead up to the punch are extremely loud, then when I do the punch the vocal monitoring level drops down the the desired level. I can't figure it out???
How do I get the monitoring level to be the same as the recording level? Please, any suggestions? My ears are ringing~~~ |
Re: Playback volume much louder than recording volume
Do you have plugins on the track? Try disabling them until you finish all the recording. Double-check all your settings as I have never had this problem unless the gain got changed or a mic cable went bad. When overdubbing, I find that if I push the track fader(which does not affect recording level) to +6-9db, that usually makes the track(and my new recording) stick out enough to hear for the recording. Once I have finished tracking, the fader gets put back to -0.
I think you're right. I record my own demos and usually, I mix the music first w/ a comp on the master bus. Then I listen to that while writing lyrics and vocal melodies, and I start singing when I have something... The compressor on the master bus was the culprit.
Thanks for the reply!!! |
Monitoring volume in Pro Tools doesn't match computer volume | Drakken | Pro Tools M-Powered (Win) | 0 | 01-17-2012 02:56 PM |
Converting Volume Automation to Clip Gain = Higher Volume! | EricWillhelm | Pro Tools 10 | 8 | 11-01-2011 11:12 AM |
Recording volume is quite compared to playback.. | broken81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-18-2009 01:27 PM |
Recording level softer than playback volume | BinkBonk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 04-17-2006 05:21 PM |
Special paste midi volume to audio volume? | Richard Fairbanks | Pro Tools TDM Systems (Mac) | 0 | 07-30-2003 09:52 AM |
