Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 12-16-2018, 08:42 PM
MPVoiceovers MPVoiceovers is offline
Default Pro Tools Ultimate - 2018 12 Crash On Startup **RESOLVED**
UPDATE 2:
Turns out it was a rewire conflict with my Melodyne Essentials version from another software pack. I followed this fix:
https://avid.secure.force.com/pkb/ar...ility/en208941
I put back the DigiRewire.aaxplugin file into the Protools app contents package, and it worked right away.
Thanks all!
Mike
So tonight I updated thru the app manager from 2018 10 to 2018 12. Everything seemed to go fine, but then on startup, Protools kept crashing right around the hardware initialize. I cleared out the plugins folders, trashed my prefs, etc... Still no go. Created a new user in OSX, tried launching there - no go.
So on a whim, I looked at the crash log to see where it was failing and this was the note:
"5982.384532,00307,0e0d: Sys_PACE::GetDigitalSignature - looking for Eden dsig for path "/Applications/Pro Tools.app/Contents/PlugIns/System Plug-Ins/DigiReWire.aaxplugin/"
5982.812206,13b07,0034: [catch_exception_raise] got mach exception: 1
5982.812251,13b07,0e0f: Access Violation:
Stacktrace:"
So I went into the contents folder of the Protools app, and deleted the DigiReWire plugin. Clicked on Protools again, and it started.
I had zero issues with the previous 2018 10, and didn't have to delete that plugin from the launching app contents folder. Any idea why this is happening??
Mike
Old 12-17-2018, 12:49 AM
BScout BScout is offline
Default Re: Pro Tools Ultimate - 2018 12 Crash On Startup
update your ilok software (PACE and Eden are references to iLok)
You haven't mentioned what your audio hardware is.
Pro Tools Ult 2020.11, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 12-17-2018, 08:45 AM
Sorry- hardware is a Zen Tour... had no problems before the 2018-12 update.
UPDATE:
Ok, so I've pinpointed the problem to be with the DigiRewire.aaxplugin file that's in the contents of the ProTools app.
When the file is left in, the program crashes almost immediately. When I delete it from the package contents, the program opens and works without any issue.
I've updated the ilok licensing app to the latest version, and all licenses have been synchronized.
Is it possible that I'm missing something? I.e. maybe I need to download something else for that plugin to work without crashing?
Old 12-17-2018, 10:59 AM
What Mac? What macOS version?
This fails when opening Pro Tools with no session right?
Have you tried trashing prefs?
Have you been using rewire in the past on this system? Do you need it to work?
You can try reinstalling Pro Tools or a clean test install of macOS on a spare drive or partition.
Old 12-17-2018, 02:54 PM
Running High Sierra. Fresh start of ProTools (not clicking a session file, just the application icon itself). Trashed the prefs and removed the plugins from the library folder. Still crashed... As soon as I went into the contents package of the app and deleted the digirewire.aaxplugin , it opened perfectly.
I've never used digirewire ever, so no big loss. But I just find it odd that now after that update it caused a problem. I even went back and downgraded to 2018-10 and still had the same issue.
Just really weird that it all started happening as soon as I updated to the latest version...
Trial Pro Tools 2018.10 Ultimate DarkOff Pro Tools 2018 0 12-07-2018 11:20 AM
Pro tools ultimate 2018 Jaymoney0079 Pro Tools 2018 3 11-28-2018 12:12 PM
2018.4 Startup Crash manfromspace Pro Tools 2018 18 05-22-2018 11:10 PM
Pro Tools 2018.4 STARTUP CRASH eddiejag Pro Tools 2018 6 05-13-2018 01:56 AM
Pro Tools Ultimate 2018.4 GUI offset by tabs error Mike Ritchie Pro Tools 2018 2 04-10-2018 04:49 PM
