Ok, firstly: thank you AVID
![]() Here is my list as to what has been fixed (on my system anyways) and what hasn't. FIXED: ![]() -Video playback not scrubbing -more stable*/ less overall crashing -most midi issues have been resolved -some import issues have been resolved- less "neo-assertion" errors -installer now installs completely and will detect if restart/ uninstall is needed- FANTASTIC new installer. Much faster install, and more options that um... actually do what you tell it to. Nice job! -Play now seems to unpack correctly and not sound tin-like upon open, but more research/usage will be necessary before I give this a "fixed" label. Now for the bad news... ![]() NOT FIXED or WORSE: -SEVERE CRASHING under certain settings... see next post below. -Resource management is very poor/CPU usage is far too high (still better overall) -occasionally setting the velocity levels on a midi track with a lot of midi data will completely crash the system. (rare, but still happens) -Random "out of CPU power" errors where there shouldn't be any... -Trouble loading older sessions with some corrupted data (this makes sense, i'll give you this one) as it crashes PT. ------------------------------------------------------------------------- *Stability determined by overall workflow verses crashing ratio, ratio is considerably higher for the latest build, but still not desirable. Note: I will update this as necessary. ![]() Thank guys for the help, and thanks AVID for finnally releasing an update, my workflow has improved, now I don't have to restart every 10 minutes... instead I just restart every few hours. ![]() And before you ask... yes I have prepared my system optimization and yes done complete and full uninstalls... ect. And for the purposes of testing/diagnostics I did install it to the default location.
Composer/Sound Designer MAC PRO 32gb ddr3 12-core 1TB D700 "DarthVader" Pro Tools 11 HD HD Omni/Thunderbolt Native A bucketload of libraries www.Reverbnation.com/jedediahjenk www.soundcloud.com/jedediahjenk notedmusic.wix.com/jedediahjenk |
Now, as for the other post...
Here are the settings I was using when my computer completely meltdown like a fusion reactor (nasty .2sec loop stuck in headphones at loudest volume, mouse would move but not click anything, keyboard would not do anything, CTRL ATL DELETE would fail, ect. I had to forcibly restart). Settings: 512 Samples @ 96K 32Bit 4 Processors ON CPU 80% Optimize for streaming Delay Comp- short What was I doing: Working on a mix with 14+ midi tracks. Medium load trailer music type of setup. Using Kontakt, Eastwest Ql, and lots of Xpand. I had this happen twice in a row, then remembering all the issues with PT 10.1.2 decided to stay away from that setting. I am running 3 CPU at 99% which actually sometimes seems less stable then 2 cores at 99%. This current setting is not ideal, as it generates a random Out of CPU power errors, but it is better than my computer crashing again. If anyone could take a look at this, that'd be great. Thanks everyone, -notedmusic.
A few observations that I have absorbed over the past few months in PT10.xx:
AMD processors seem a little less stabile than Intel. With heavy VI content, use three as opposed to four processors, and disable multi processor use in Kontakt. Don't mix "Kontakt" with "Play" in PT, use a ReWire application such as Reaper. Or go with VEPro.
~ tom thomas Formerly hobotom Pro Tools Ultimate 2020.12 HDX HD Omni and 192 I/Os Windows 10 Intel Hexcore i7 All Samsung Pro SSDs Ampex MM1200 2" 24 trk tape Outboard: UREI, Eventide, Lexicon, Yamaha, TC Electronics, Orban, ART, EchoAudio, Dolby, Hughes, API, Neve, Audio Arts, BBE, Aphex, Berringer, MOTU, dbx, Allison, etc. Plug-ins: Too many to talk about. www.metrostudios.com |
![]() Quote:
On a side note, it would be nice if AVID would allow me to import velocity into Sibelius... or choose whether I want to or not. Then I can just convert velocity to dynamics and that would save a LOT of time. For some reason going directly into Sibelius preserves the notation, but looses everything else, even tempo data and markers. But this isn't an issue of stability, only convenience. ![]() So any reason in particular I cannot mix kontakt and play? Does this cause issues with them fighting over ram or something? Thanks -notedmusic
Have Nahalem HyperTread issues been resolved? | cananball | Pro Tools TDM Systems (Mac) | 2 | 10-18-2011 10:35 AM |
when will the IE8 and DEP issues be resolved? | bfrazer | Pro Tools M-Powered (Win) | 6 | 03-08-2010 07:04 PM |
when will the IE8 and DEP issues be resolved? | bfrazer | Pro Tools M-Powered (Win) | 5 | 02-17-2010 02:33 PM |
When will these retarded midi issues be resolved????? | Buff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-26-2008 12:34 PM |
Mirror Door issues... resolved?? | AdamF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-21-2003 02:49 PM |
