Old 07-22-2019, 10:37 AM
KenSluiter KenSluiter is offline
Default When is "Eucon" going to feel like it's an Avid product?
As much as I dislike Avid bashing, I'm can't help but to say that often as I'm mixing, I feel like I'm fighting my artist controller. It's like I'm trying to mix, and the controller is trying to stop me.
Today, my artist mix is inexplicably reverting to the first eight tracks in the session. As I then "select" the track I'm trying to work on, the automation line goes red when I touch the fader, but then it doesn't record the fader moves. When I stop the transport, the fader I'm holding is now a different track. WTF?
I'm no Eucon ninja (I never thought the products/protocols were "tight" enough to bother learning anything other than pushing faders around), but I've been using this artist mix for a long time, and every time I install a new version of Eucon, my hope is that it will work more reliably and it never does.
I could list a bunch of other behaviors that I see w/ the Artist mix that don't make any sense. My point is not to fix the issue that brought me here today (instead of mixing my clients' record), but just to tell Avid that my experience w/ the Eucon protocol doesn't make me want to invest more $$$ into another controller.
And now, because I'm on a deadline and need to deliver mixes, I will pull out my Presonus Faderport so I can finish my vocal ride as that will be faster than combing thru google posts reading about everyone else's frustrations w/ Eucon.
How embarrassing for Avid that a sub $200 product that's over 10 years old will help me finish my work while my $1000 (at the time) Artist Mix will now sit until I have time to troubleshoot.
my 2 cents
Ken Sluiter
MacOS Mojave 10.14.5
Pro Tools Ultimate 2019.6
Eucon 19.5.1.44 REL
Old 07-22-2019, 12:22 PM
KingTor KingTor is offline
Default Re: When is "Eucon" going to feel like it's an Avid product?
I hear you. FWIW, that particular behavior used to annoy me a lot. I've gotten in the habit now of mixing with "link track and edit selection" off within pro tools and that seems to help. I hate having to learn how to workaround what I consider to being flaws, so I know this won't alleviate your underlying frustration, but it might help you be a mixer more often, which is what the whole investment is for, right?
sent from a stupid phone using Tapatalk
Tor Kingdon, Chief Sound Guy
Hear Kitty Studiostwitterfacebook
Old 07-23-2019, 07:59 AM
EddieJones's Avatar
I think the fact that you say that after every release it doesn't get better indicates there's something else at play. Faulty unit, bad network setup etc. Many on here have posted on how the software has gotten much better over the past couple years and how reliable it is now.
I'm presuming you are running 19.5.1 ? and what version of PT ?
Old 07-26-2019, 05:22 AM
my 2 cents
Ken Sluiter
Eucon 19.5.1.44 REL
Could be your faders falling apart. I've replaced mine twice already. It usually starts with me moving the fader up but hearing the level go down (and vice versa) (which is also reflected by the automation kurve in PT). AVID's official repair contractor here told be it's typical for faders sending bogus data to PT when they wear out or get dirty. Replacement is the only cure and they usually replace all 8 because when one starts to fail the other will soon to from their experience.
You can test this by going into diagnosis mode and then see if the hardware is actually working correctly.
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Pro Tools product shows "No download available" (missing all installers) Dot Licensing & Accounts 52 12-15-2016 09:35 AM
"Pro Tools 11.0 for Students Verified" product showing wrong downloads hell900307 Licensing & Accounts 2 04-25-2016 06:25 PM
"Welcome to Avid Product Registration" window continues to open when launching PT krem2 macOS 59 06-03-2015 07:05 PM
The product activation site is currently returning "database error" for all logins. corywest General Discussion 4 11-15-2009 11:54 PM
