Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 07-06-2018, 02:26 AM
kava kava is offline
Default buttons in knob expand don't work anymore
Hi all,
I'm expanding plugins - aax channel strip in this case - to a knob module on my s6m40.
all the rotary functions are mapped and are working on both pages of channel strip.
but the push buttons aren't! i cannot toggle bands on/off. I cannot switch shelf/bell types etc...
i looked at the channelstrip .xml in the plugin an everything is mapped correctly (never changed anything)
buttons are working when knob module is just used for panning, sends etc...
any ideas? s6 is on 18.3.0.219. PT ultimate 2018.4
2xMac Pro 2014 6-Core, 48GB Ram, OS X 10.12
ProTools HD12 and Ultimate, 2x HDX
NTP Penta720 I/O + 192 HD I/O + SSL Madi Link
Sync HD, Dolby Atmos RMU
S6 - M40 - 32channel.
Filmpost at cosmix studios vienna
http://www.cosmix.at
http://www.tom-kava.com
Old 07-06-2018, 07:14 AM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Default Re: buttons in knob expand don't work anymore
Greetings,
Thanks for the observation. It looks like you are absolutely correct. The channel table behaves correctly for Insert params (teal) with regard to band enable and shelving/parametric, however the expanded table is behaving badly. Dedicated EQ (magenta) and DYN (green) seem fine as well. Investigating and writing it up now...
Jeff
Jeff Komar
Applications Specialist, Pro Audio
Old 07-08-2018, 09:41 AM
EddieJones's Avatar
I don't think this will fix your issue but you should download 18.3.0.244 from your account as there were a few bug fixes in it.
Old 07-08-2018, 10:07 AM
The issue is there with current versions as well. I tested on S6 18.3.0.244 and PT 2018.4. FYI.
Jeff
Jeff Komar
Old 07-17-2018, 07:44 AM
I've updated now, and yes the problem is still there, but it seems its only happening with channel strip, using buttons with pro-compressor for ex. works fine.
best+thanks for investigating
thomas
Octave transpose buttons don't work sytrusze Pro Tools 11 0 12-20-2014 11:51 AM
S3 buttons do not work [SOLVED] Cliffy_Boy Pro Tools | S3 7 12-09-2014 04:35 PM
002 buttons no longer work? Jay002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-22-2011 07:07 PM
Control 24 & PT LE, only some buttons work! weezy ICON & C|24 2 08-29-2005 08:15 AM
When will all the buttons on C24 work? syra ICON & C|24 5 08-30-2003 10:32 AM
