Old 09-06-2017, 11:35 AM
Mark Ziebarth Mark Ziebarth is offline
Default Fixed vs floating point processing
I have two setups in my studio: My main room is still PT HD 10 with HD 3 and the second room is PT 12 HD with a Fireface 802. Sometimes I start a session on 12 and mix it in 10. McDSP support told me that the general difference in maths (32 bit fixed point in 10 and 64 floating point in 12) may cause problems. The second room is bigger for more clients but not a real mixing room. My question: What should I take care of to avoid to run into trouble while using a Session started in 12 in 10? Normally I'm using a little Channelstrip here and there in the recording session and never remarked a difference when opening the session with the older software.
What I know is I have to look for the gain staging.
But does anyone have any practical examples when those maths differences are important for session compatibility between 10 and 12?
Any help appreciated, best regards
Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate
Mac Pro 2008, RME Fireface, Pro Tools 12, Euphonix MC Control
Old 09-06-2017, 11:46 AM
reichman's Avatar
reichman reichman is offline
Default Re: Fixed vs floating point processing
Yup. If you send a bunch of hot tracks to a bus in fixed point and it clips, when you turn down the bus, it just makes the clipping quieter. In floating point, turning down the bus actually gets rid of the clipping. First time I heard this, my jaw dropped. Floating point mixing is very different. If you properly gain stage the old-fashioned way in PT12, you shouldn't run into trouble, but keep your ears open.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 09-06-2017, 11:49 AM
That's good news, thank you. I'm old school so my gain staging is appropriate, normally... But this support message confused me...
Old 09-06-2017, 12:01 PM
If you started in the early days of digital audio like me the floating point maths is a weird thing. I would never lower the volume of the buss if the signal input is too hot. But I understand it's possible with actual software and that's a good thing.
That's why I like the DUC so much. Just this one answer of you Nathaniel helped me a lot. Good to have you here! Thanks again.
Old 09-06-2017, 12:20 PM
reichman's Avatar
You're welcome. There's a lot more to it than that, but the bussing is a place where people get into trouble.
Nathaniel Reichman
Dubway Studios
Old 09-06-2017, 12:31 PM
Yeah, the bussing issue is a practical example to understand the difference. Simply a good advice! I understood and am happy now! Go on with the good work! Next year I'm in here for 20 years, huh...
Old 09-06-2017, 12:43 PM
There is nothing that is 32 bit in "10", and by that I assume you mean 32 bit fixed point in legacy HD/TDM? Pro Tools legacy HD/TDM processing is 24 bit fixed point plugin processing and 48 bit fixed point mixing. Current Pro Tools (and Pro Tools HD Native) and Pro Tools HDX are 32 bit float plugin and 64 bit float mixer. In both case the plugins can also operate internally at the higher (48 bit boxed/64 bit float mode if needed).
Old 09-06-2017, 12:52 PM
Thanks Darryl, you're completely right. But I was just searching for situations where this maths matters. And my result is: If you're gain staging old school nothing obvious can happen. Am I wrong?
Old 09-06-2017, 01:39 PM
If by "gain staging old school" you mean you never make a mistake in gain staging and you trust the plugin developers did a good job then sure nothing can go wrong. But assuming you never make a mistake is uh optimistic. It's always nice to have more headroom.
But even with 32/64 bit float processing you still need to gain stage stuff/watch levels. The input level matters greatly to what the plugin is modeling/going to do with that signal.
Old 09-06-2017, 02:28 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Only very simple 32 float plug-ins that aren't modeling analog gear don't require gain staging. Even then some go crazy when confronting over the top signals. It's best to turn the signal down before applying signal processing and then turn it back up at the end of the signal path.
Bob's room 615 562-4346
Georgetown Masters 615 254-3233
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Floating Point Denby macOS 7 05-09-2013 02:53 AM
Fixed Point vs. Floating Point Oblivion777 Pro Tools 10 19 12-15-2011 06:46 AM
fixed/floating point changes? rikttt Pro Tools 9 0 11-14-2010 05:20 AM
Floating Point/ Fixed Point/ Dither Nika Tips & Tricks 2 02-15-2005 12:05 PM
HTDM: Floating point processing? worldsound73 General Discussion 0 01-18-2002 02:55 PM
