Old 01-09-2017, 05:14 AM
Stig Eliassen's Avatar
Default Blue vs black XMON
Can anyone shed any light as to the difference between the two?
Thank you.
Old 01-13-2017, 01:02 PM
Default Re: Blue vs black XMON
Kudos to Avid Support. Got a new PSU from Dublin, replaced the old one, and I'm back in business.
Thanks!
Old 01-14-2017, 09:53 AM
Drew Mazurek's Avatar
Nice!! Glad you got it sorted!
www.drewmazurek.com
Old 01-14-2017, 11:12 AM
Marco Bernardo's Avatar
Marco Bernardo Marco Bernardo is offline
I think the only difference is the Color and the end of date support. The tech inside is the same.. I could be wrong.
Regards.
Marco Bernardo
Dialog Editor, Sound Designer, Re-Recording mixer
nMacPro 6Core/D500/512GB/64Gb ram | PT HD 12 HDN Thunderbolt | HD OMNI | Avid Artist Mix | Novation Impulse 25 | Waves Mercury Native | Audioease All In Bundle | SoundToys | McDSP Classic Pack | DUY Overpack | Arturia Beatstep Pro
Old 02-04-2017, 03:20 AM
Dang it, it didn't last long. Here's what's happening intermittently:
- the XMON shows as "Off" on the console
- the mute button becomes active on its own
- the sound disappears, and (usually) twisting the CR level knob will get sound back
- with PT idle, a relay in the XMON ticks back and forth on its own
I have tried re-seating every cable on the XMON and the console.
I have tried resetting the XMON.
I have tried resetting the console.
I'm thinking that something more than the PSU in the XMON took a hit when I had a power outage. ANY thoughts and tips are appreciated, including buying something other than an XMON for monitoring.
EDIT: Is there ANY chance that a faulty cable (XMON <-> D-Command) can cause this? I have a deal on a used XMON, but wasting money is not my favorite hobby.
Thank you ever so much in advance.
Old 02-04-2017, 07:06 AM
Something is severely wrong. Even with the XMON muted and "off", the speakers suddenly emitted noise, and insanely loud. I had to turn off the sub and nearfields.
Old 02-04-2017, 03:59 PM
remotedude's Avatar
remotedude remotedude is offline
Can you bypass around the XMON to see if the noise you're hearing is coming from the XMON or the system. We had an issue where we'd get noise blasts coming from the system. Full bore. Turned out to be a faulty HDX card. Just a thought.
Old 02-06-2017, 07:42 AM
Yes, I have a Benchmark DAC1 for monitor conversion. I flipped it over to "variable", meaning that I control the CR volume with the stepped knob on the front, and I just plugged the analog outputs directly to my sub/nearfields.
I've had PT/Logic looping a song for a couple hours, and it works just fine. The XMON is broken, no doubt about that.
Thank you.
Old 02-10-2017, 06:37 AM
Watagushu2013 Watagushu2013 is offline
I think 2 years ago I had to replace the output card from my xmon because of a similar problem and strange behavior. Try to get in contact with someone that can test it or have it serviced.
FS-Blue D-Control 16 Fader Surround, Xmon. drogan88 Buy & Sell 0 08-19-2016 06:52 AM
Xmon connected to Black magic why it's mono? asef@me.com ICON & C|24 9 01-25-2015 05:55 AM
Xmon blue or black - whats the difference? Jakob Clemen ICON & C|24 4 12-12-2012 05:20 AM
Blue D-Command +Xmon + 192 DIGITAL neilvg Buy & Sell 1 10-19-2012 07:09 PM
WTB: D-Command Main Unit Blue w XMON efisch Buy & Sell 0 06-08-2012 08:27 AM
