Old 07-22-2015, 02:05 PM
JuanPC JuanPC is offline
Default PTHD9.0.6 Windows 7 sp1 32-bit, Native ASIO mode.
Has anyone have the same bug?
When I bounce to disk there is a "pop" click at the start of the audio file.
If I click: "Don't ignore Errors During Playback/Record."
It's louder, seems like some buffer/cache was not empty.
I have tested 2 soundcards, Lynx AES16 & Rme hdsp9632.
The Linx has something called SyncStart(TM), if I move that, sometimes the cache bug goes away completely.
The answer was: "fingers cross",
If click Smallest cache size & click on minimize system memory.
Bug is gone.
Also the option for "minimize system memory."
If I set Cache Size: Long,
And play/hear the file before I bounce, bug returns.
Latency compensation long in all tests.
Cache size has nothing to do...
Bug is back.
Seems I need to quit PTHD & run again, to bounce without hearing/playback, to avoid the bug.
Or bounce again without quitting PTHD, but without hearing/playback to avoid the bounce.
the bug is related to VST to RTAS adapter.
Will test with different plugins.
Bug only affects bounce, Playback works fine.
It was a Crysonic plugin with the VST to RTAS Adapter. Look ahead buffer latency compensation wrapped related bug.
[IMG] code is Off
HD Native Thunderbolt Asio driver for Windows 7? greenfendr Pro Tools HDX & HD Native Systems (Win) 1 07-13-2015 12:08 PM
Mbox 2 doen't works in ASIO Mode in Windows 7 x64 with thrid Party Software Nenugr FireWire and USB Audio Interfaces (Win) 3 08-21-2013 10:14 AM
When to upgrade PTHD9 to 10 (probably native) Tim R. Pro Tools 10 13 03-13-2013 08:41 AM
Windows 7 HD Native Asio Unknown Error in 64 bit apps MrTom2003 Pro Tools HDX & HD Native Systems (Win) 1 09-19-2012 11:26 AM
PTHD9 and windows 7 64bit and aurora8 abomeerza Pro Tools 9 6 11-18-2010 04:41 PM
