  #181
Old 01-19-2019, 06:50 AM
Oliver M Oliver M is offline
Default Re: Automation AppleScripts for Pro Tools (Mac)
For some reason I cannot post any code to this board, access denied?!?!
  #182
Old 01-19-2019, 06:56 AM
Here's a download link for the code I intended to post.
AppleScript_for_Johannes.scpt.zip
Install cliclick in /usr/local/bin/.
  #183
Old 01-19-2019, 09:03 AM
its2loud its2loud is offline
this works like a charm. Thanks Oliver!
I've added in the script to type in the preset name. Just replace the line with "your preset name here" with the name of the preset you want to recall.
https://drive.google.com/open?id=1Da...7MlX5Hb99y_mxN
The rest is up to you how you want to implement the script.
keep in mind, to install cliclick in the specified directory you will have to show hidden files and folders in the Finder. The easiest way to do this is open the Finder window and hold Commnd+Shift+. Then drop the cliclick file in the appropriate folder.
cliclick can be downloaded here
https://www.bluem.net/en/projects/cliclick/
  #184
Old 01-19-2019, 12:13 PM
johannes1 johannes1 is offline
thanks a lot guys. thats it!
i added:
click button "RENDER"
after the first end tell.
wow, now i have to make sure not to move my mouse while executing the macro… otherwise it could do a lot of mess. i wonder if there is way to tell applescript to block mouse or trackpad inputs during the macro¿
  #185
Old 01-19-2019, 12:27 PM
not really sure about that. Considering the script runs in a matter of seconds I wouldn't think it would be a big deal to just take your hand off the mouse when using the shortcut key to run the service/script.
by the way. this script only works if the De-click window is already showing on screen.
I've written a script that will call up the De-click, or any other plugin, if it's not already showing, then execute the remaining commands.
A lot of folks I know use Xkeys for executing these various scripts while editing and such. Makes for a really great workflow. Personally, I've made some user softkeys on the S6 execute these scripts so I don't need Xkeys.
  #186
Old 01-19-2019, 12:48 PM
i see. just tested it with my macbook and its trackpad… will see how it works in my studio. probably just like a dream.
at work the rx declicker is always visible on the second monitor since i use it the whole time. and yes using a xkeys - one key triggering – is great. now i make 3 declick presettings from subtle to hard and map them on 3 keys. ace!
what makes a lot of sense regarding workflow:
i added & " -r " to the shell part at the end of the script which preserves the cursor position on the screen. so you didnt have to "pick up" the cursor from the declick window over and over again.
  #187
Old 01-21-2019, 05:19 AM
Drew Mazurek's Avatar
test
Code:
test
www.drewmazurek.com
  #188
Old 01-21-2019, 07:08 AM
2nd test...
Code:
Thx Drew!
  #189
Old 06-02-2019, 04:48 PM
Kevin Peters Kevin Peters is offline
Hello,
I'm not sure anyone will be able to help with me, but I've been trying to write a script that will open the pan window of the selected track.
I have successfully done it by looking at the track list group and cycling through all the tracks (which are rows) and finding the first track that is selected. I then take the string from a button that belongs to that row/track and format it to the string I need to actually call on that specific track in the edit window.
Below is the script that works in Pro Tools Ultimate 2018:
Code:
tell application "System Events"
	if exists (process "Pro Tools") then
		tell process "Pro Tools"
			tell (1st window whose title contains "Edit: ")
				-- Essentially gets the title of all the tracks in the track list, which is the only place I've found that tells you what is selected.
				set buttonList to title of (1st button of UI element 2 of row of table "Track List" whose title contains "Selected")
				repeat with theItem in buttonList
					if theItem contains "Selected" then
						-- Formats the string to what it needs to be to access it's buttons by stripping "Selected. " from the start of it and then correctly formats the type of track it is, which you don't have to do in v2019
						set selectedTrack to text of theItem
						set AppleScript's text item delimiters to "Selected "
						set theTextItems to every text item of selectedTrack
						set AppleScript's text item delimiters to ""
						set selectedTrack to theTextItems as string
						set AppleScript's text item delimiters to " audio track"
						set AppleScript's text item delimiters to "- Audio Track"
						set AppleScript's text item delimiters to " auxiliary track"
						set AppleScript's text item delimiters to "- Aux Track"
						set AppleScript's text item delimiters to " master track"
						set AppleScript's text item delimiters to "- Master Track"
					end if
				end repeat
				-- Confirms the button is there before clicking it
				if exists (button "Output Window button" of group "Audio IO" of group selectedTrack) then
					click button "Output Window button" of group "Audio IO" of group selectedTrack
				else
					return
				end if
			end tell
		end tell
	end if
end tell
And since the string was changed a bit this is the code for Pro Tools Ultimate 2019.5:
Code:
						set AppleScript's text item delimiters to "Selected. "
					end if
				end repeat
				else
					return
				end if
			end tell
		end tell
	end if
end tell
Now while these scripts work, when a session gets big with a lot of tracks it can take way to long for the script to complete. I believe the bottleneck is that is essentially iterates through all the tracks twice, but I haven't found a more optimized way of doing it.
Soundflow does something similar and it does it much quicker. While I think Soundflow is an incredible program, I need to personally customize my code because I'm constantly trying new things and tweaking.
If no one know the answer to this, hopefully someone will benefit from the above scripts. And thank you to Oliver for doing all the hard work for this thread.
  #190
Old 06-02-2019, 05:46 PM
To improve upon my post above, I looked through the UI elements of the Track List again, and it turns out that the rows (tracks) in the "Track List" table have a parameter called "Selected" that has a true or false value. Using this new information here is my updated script for 2019.5:
Code:
				set selectedTrack to title of button of UI element 2 of (1st row of table "Track List" whose selected is true)
				set formattedString to text of selectedTrack as string
				set theTextItems to every text item of formattedString
				set formattedString to theTextItems as string
				click button "Output Window button" of group "Audio IO" of group formattedString
			end tell
		end tell
	end if
end tell
This dramatically increases the speed of the script, although there still is a 1/2 second to 1 second delay in really big sessions with hundreds of tracks. That being said in a small session it's a very short delay. I wonder if there is still a way to speed it up. I got rid of the safety check on the button so save a split second.
Using this script you can change it to open any of the visible inserts, sends, and other buttons on the track.
Pro Tools 12 Trim Automation bleu@cheerful.com Pro Tools 12 2 08-16-2015 04:25 AM
Pro Tools 11.2.1 Automation Bug?! Gneal550 Pro Tools 11 1 11-22-2014 01:15 PM
GRM tools automation bug? D'Animation Pro Tools TDM Systems (Mac) 6 10-08-2014 08:21 AM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 12:38 PM
AppleScripts and other Macros for PT Bergeron Tips & Tricks 1 11-15-1999 06:55 PM
