Old 03-23-2011, 11:26 AM
stvnscott stvnscott is offline
Default Re: Anyone Else Hearing a Fuzzy Phasing Thing in EXP with High Gain Patches?
^ It might be a more acute manifestation of the same thing, but 1,000,000 times worse since yesterday.
Old 03-23-2011, 11:55 AM
LittleWiggler LittleWiggler is offline
I am hearing it as well on my system. I thought it was my ears, but on just about every high gain factory patch there is a smear (for lack of a better term) that trails into some nasty digital artifacts as the noise gate kicks in on sustained notes.
Old 03-23-2011, 11:59 AM
I noticed it right away when I installed the EXP. I started out playing the cleaner amps (for several hours) and could tell something wasn't right (something smeary and fuzzy going on), but I was really enjoying the new models and new effects. When I hit the RC Boost for the first time, it really came out and I went into "Rut roh" mode.
Old 03-23-2011, 12:28 PM
Lution Lution is offline
I couldn't make out what you were talking about in your first clip, but I certainly hear it in your second clip.
hmm. It doesn't sound very good at all. Can you share your settings at I'll try to recreate it here. Or is it a factory patch?
Old 03-23-2011, 12:34 PM
^ The second clip is the factory Browntown patch. Switch the amp to the Plexi Variac and the cabinet to the 4x12 20W to really bring it out.
  #16
Old 03-23-2011, 01:30 PM
PSD PSD is offline
I think what you are hearing is frequency cancelation between the two channels (vol 1 and vol 2) of the Plexi head. The effect will be more pronounced with a brighter sounding mic/cab combo. Try turning either volume 1 or 2 all the way down and listen again.
I'm sure Chris can give a better explanation though :)
  #17
Old 03-24-2011, 02:01 AM
Leonb Leonb is offline
Frequency cancelation between two channels, that's a good one.
That could explain the effect. And it will act like a comb filter if there is a slight delay between the two channels. I'll see what happens if I turn one of the channels down
Leon
  #18
Old 03-24-2011, 04:09 AM
So, I checked it out:
cancellation of the two channels does cause this phasing sound.
I think this is natural behaviour, and it is "as designed".
I did not notice this before because in my case there is allways one channel much stronger than the other in my plexi-patches.
Leon
  #19
Old 03-24-2011, 06:37 AM
PSD PSD is offline
Leon
Yes the Plexi's behave like this in the "real world" too
  #20
Old 03-24-2011, 11:42 AM
^ Not mine, but that's a debate for another day.
Here is a very glamorous clip of me tuning my E and A strings. Old plexi model. Gain 1 turned all the way up. Gain 2 turned all the way down. 25W 4x12 cab. True-Z on 1M. Speaker breakup on 0.
I'm going to try to revert to 1.3 now to see if that fixes it. My 11R is completely useless now.
http://soundcloud.com/stvnscott/phaseytuning-11r-guitar
Can 11r do the high gain? derker Eleven Rack 4 10-05-2012 01:03 PM
RESOLVED: Fuzzy patches after playing in standard C. Hotcrazyfruit Eleven Rack 10 03-24-2011 03:55 PM
High Gain Patches and Weird tones SimonBarSinister Eleven Rack 9 01-11-2011 06:10 PM
The Monsters Of High Gain Benoni Eleven Rack 13 12-17-2010 06:59 PM
what's this 'high definition' thing? daddykev 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-11-2002 04:39 PM
