Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 09-28-2010, 03:57 AM
flash_usb flash_usb is offline
Default Importing Pro Tools 5.1 (PC) tracks to Pro Tools M-Powered 8.0.3 (Mac)
When opening Pro Tools 5.1 (Windows XP) Sessions with Pro Tools M-Powered 8.0.3 (Mac OS X), I get the following error message: “Could not open because the session was created with an invalid configuration of Pro Tools”. Following the similar thread, I tried to set the same regional settings on Mac as on PC, but it didn't help. Deleting Pro Tools databases and preferences didn't help either.
I have no access to the original Pro Tools 5.1 system, so I can't save them in PT 5.0 format. SSL Pro-Convert seems too pricey for just three sessions. Audio data is stored as regular WAV files, so as a last resort I can rebuild them from scratch, though it can require a lot of time.
1. Is there something else I can do to open them?
2. Is it possible to save these sessions as PT 5.0 having only session files, without the actual audio data? In this case perhaps I can send them to someone able to open them and save as PT 5.0.
Old 09-28-2010, 12:29 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default Re: Importing Pro Tools 5.1 (PC) tracks to Pro Tools M-Powered 8.0.3 (Mac)
Instead of LOADING the session, have you tried IMPORTING SESSION DATA into a new session?
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 10-01-2010, 07:23 PM
Yes, the same error message appears when importing session data too.
Old 11-02-2010, 05:27 PM
robs001 robs001 is offline
I have the same issue except in reverse PT5.1 (Mac OS) to PT8 003 (Win XP) ...
www.oatmeal.com.au
How can I Importing Vienna Ensemble pro tracks to Pro-Tools without re-enable them? Vishnoo macOS 1 03-03-2015 09:52 AM
Pro tools importing tracks problem Willave15 Post - Surround - Video 5 04-05-2011 04:26 PM
Importing with Pro-Tools M-Powered Essentials Nirrad Pro Tools M-Powered (Win) 1 03-20-2011 07:10 PM
importing reason tracks to pro tools spkuo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-27-2004 10:21 AM
Pro Tools quits while importing tracks... zafricandekeiko Pro Tools TDM Systems (Mac) 11 11-18-2003 10:44 AM
