Old 08-08-2019, 10:18 AM
abre abre is offline
Default Re: Cancelling subscription
Thanks.
Old 08-08-2019, 10:27 AM
Default Re: 2019 Activation process
Originally Posted by abre View Post
Can anyone tell me how to go about activating Protools 2019? I did a cross grade but I cannot activate the software. Where does the activation code come from and how are they deposited in your ilok?
Make sure your iLok 2 or 3 is plugged in and working.
Did you purchase direct from Avid? You have to go to your master account and in your products section pick the license you want to upgrade from. If your iLok account is linked to this account once you make the selection the system will trundle along and the license asset should be on your iLok.
Just to be sure the license asset is on your iLok login to the ILM software and check to see if it's there; you may have to sync your iLok with your iLok account.
Old 08-08-2019, 10:36 AM
A co-worker did the cross-grade and was never given a license. He recently received an email from Avid, apologizing and stating that the license was finally deposited into his account. If no license has been deposited into the Available tab of your iLok license manager, then you should contact Avid's licensing support department. Avid's support can be somewhat difficult to navigate, but licensing support should be free and no system ID or ASC should be required.
Scott Gatteρo
Yessian
Old 08-08-2019, 01:13 PM
Did your co-worker select the license he wanted to give up from his Avid master account? You have to do that before you get the license.
Old 08-08-2019, 01:42 PM
It was generated. Everything up and running smooth. Thanks.
Old 08-08-2019, 01:55 PM
xrekcor's Avatar
xrekcor xrekcor is offline
excellent to hear you finally got it sorted... customer service here is pretty good once you get a support ticket happening
Rob
MBP 15” 2018 macOS Mojave 10.14.6 Touch Bar and ID
Pro Tools 2019.6-23.#, Cubase 9.5, Yamaha TF5, UR44, BEHA4700
........and a bowl of M&M's
Old 08-08-2019, 04:45 PM
He did. And the license that Avid finally deposited reflected the surrender correctly in the details pane of ILM.
Scott Gatteρo
Yessian
Old 08-09-2019, 04:02 AM
This thread indicates that there really needs to be a solid set of steps for doing the upgrade/crossgrade from say PT9 or 10 or 11 and whether you buy direct from Avid or third party like Sweetwater. For instance I didn't have to have the ILM s/w open to surrender the license asset I wanted to upgrade from as I just did it from my Avid master account. There's little bits & pieces floating around on how to do the upgrade/crossgrade but nothing in one place.
Maybe something like a sticky in the Licensing or 2019 subforum.
Old 08-09-2019, 05:04 AM
Problem solved.
PT 2019 not recognizing ilok activation pgripp Pro Tools 2019 4 07-26-2019 11:53 PM
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 08:30 AM
Download and Activation Process tryn2chanjdgame Pro Tools 9 1 11-26-2010 04:07 PM
Problem populating HD 4 accel + Process + Process Brandonx1 Post - Surround - Video 6 07-15-2010 04:40 PM
hd process and accel process in same machine? blumediaprojekt Pro Tools TDM Systems (Mac) 1 02-01-2006 07:51 PM
