Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 07-14-2019, 11:26 AM
aigroeg1997 aigroeg1997 is offline
Default Built-in Output not working
Hi guys, i'm trying to record guitar through my Axe Fx ii into a Scarlett 6i6. Pro Tools has recognised my Scarlett as the main input, and is picking up the signal from my guitar when i try and record something, however, i'm getting no sound from my Built-In Output (Mac Speakers) when i'm recording or trying to listen to listen back. I've tried going on the 'Hardware' option and choosing my Built-in Output, but yeah its just not working.
I am a bit of a noob, so hopefully someone can give me a simple answer to what i'm missing!!
Old 07-14-2019, 01:40 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Built-in Output not working
Need system info but i will say that Pro Tools will only use one "audio engine" at a time, IOW, F'rite or built in sound but not both. If you are monitoring with headphones you need to connect them to the F'rite, not built in.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 07-15-2019, 09:29 AM
junkgear's Avatar
junkgear junkgear is offline
Like 64GTOBOY said, you can not use two different interfaces at the same time with Pro Tools. Your Mac however allows you to create an aggregate audio interface, which can contain different audio devices.
First create an aggregate device on your Mac containing the devices you wish to include. Once that is created, start PT, go into your playback engine and choose the new aggregate device as your audio source. You should now be able to route the audio as you please.
Will K
System Details
9173 only appear when using Built In Output MorganIR Pro Tools 12 1 08-11-2017 04:33 PM
built in output on mac stopped working-works fine in 10 mortenbrekke Pro Tools 11 1 07-09-2013 01:48 PM
HDX & Built-in Digital Output? sfere1 Pro Tools HDX & HD Native Systems (Mac) 1 11-03-2012 07:45 PM
8PRE input with built-in mac output? nhwinni macOS 9 02-14-2011 08:17 AM
No output from Mbox: built-in phone output only DaveSullivan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-19-2006 06:03 PM
