Input monitoring issue with PT10
Hi everyone,
Weird issue I just came across. I'm at a post house and one of the computers is doing a weird thing where it doesn't properly toggle between input and playback on a record track. Or when switched to PEC/Direct, it doesn't toggle between the two. I would feed audio through a bus to a new track (i.e., stems to the print master) and as it plays, it wouldn't switch between input and playback at all despite the green "I" light toggling on and off, the signal just feeds right through the track. Of the many Pro Tools rigs in the building, this is the only one acting this way. I tried trashing preferences, re-installing pro tools, clean reformat of the hard drive and a reinstall of the OS as well as pro tools and I still have the issue. Anyone else come across this? Intel Mac Pro Mountain Lion 10.8.5 2x2.4GHz Quad 16GB RAM Pro Tools HD5 through Magma Chassis (Core, 2 Accel, 2 Processor) 4 192's Blackmagic Intensity Pro Pro Tools 10.3.9 |
Re: Input monitoring issue with PT10
TDM with 10.3.9 has issues with input monitoring....noted issue
I believe the fix is to use 10.3.8 HD|N and HDX not affected
That is correct. 10.3.8 has an AAF bug, so you might as well revert to v10.3.7.
Back to 10.3.6 on TDM here, pretty OK.
10.3.7 has no issues for me....input monitoring bug? What input monitoring bug!?!?!?
Thanks for the help everyone! Reverting back down to 10.3.7 did the trick. I guess "over updating" is a thing.
This bug only affected HDN and HDX, right?
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
No, only HD TDM systems.
Input monitoring issue | Colorblind | macOS | 0 | 10-13-2012 08:15 AM |
Input Monitoring with non-HD PT10 Advice ? | gatelyc | Pro Tools 10 | 3 | 09-06-2012 12:40 AM |
Auto input/input only monitoring failing in PTLE 8.0.4 | miketeachesclass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-11-2012 08:48 AM |
auto input monitoring issue | jntracks | Windows | 10 | 02-07-2011 05:37 AM |
Auto Input monitoring / Input only monitoring - Alt+K | AdamPT8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-09-2010 10:50 AM |
