Old 07-15-2014, 06:50 PM
ChrisMac ChrisMac is offline
Default EQ with EQ III shortcut
Is here any other EQ plug on the market that does the shift click short cut of EQ III? In case you are not familiar with the short cut, with EQ III you can boost a frequency and then shift click the band to turn the boost to a cut of equal value.
Chris McIntosh
President/Sound Supervisor
Postal Audio Inc.
Imdb
Facebook
Old 07-15-2014, 07:17 PM
Craig F Craig F is offline
Default Re: EQ with EQ III shortcut
if you're looking for a cut only EQ the McDSP NF575 has a band solo (automate-able)
Thank you,
Craig
Old 07-16-2014, 12:31 PM
That looks great but what I want is something that I can sweep around to find suspect freq and then lower them but not necessarily notch them
Chris McIntosh
Postal Audio Inc.
Imdb
Facebook
Old 07-16-2014, 12:57 PM
propower propower is offline
Fabfilter pro Q is my favorite interface. Dial a cut with sharp Q and then click hold the band solo (little headphones) to find the problem - release - done.... Even has spectrum in the background if you like (which I do)...
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 07-16-2014, 01:04 PM
sorry, maybe I am a bit unclear. What I want to do is boost the frequency by say 10 dB, narrow Q, and then sweep around to find the bad frequency, which now will stick out like a sore thumb. Once I find the freq, I want to just shift click the boost and turn it into a cut. Comes from my old school days of working on consoles and sweeping eq's
Chris McIntosh
Postal Audio Inc.
Imdb
Facebook
Old 07-16-2014, 01:17 PM
I get you -
Isolate the freq- cut
ProQ does this brilliantly - but not exactly as you describe. The soloed band exposes the badness without having to put in some giant boost. But - again - I get ya - if it has to work exactly like you describe - this is not your answer.
Old 07-16-2014, 02:09 PM
the McDSP can sweep and it can go wider than notch, it's that it goes narrower than most
has some comb-filter presets as well
try the 14 day demo, worst case you like it and buy it
Thank you,
Craig
Old 07-17-2014, 06:00 AM
elicious elicious is offline
hey chris, epure eq will do that.
it has the added flexibility of performing this per band
or across all bands.
e
for the record
ihatetyping
Old 07-17-2014, 11:48 AM
cananball cananball is offline
Avid Channelstrip
Ken Wilkinson
http://kenwilkinson.tv
Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1
2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5
Old 07-17-2014, 02:07 PM
Brandonx1 Brandonx1 is offline
What's wrong with eq3? Still the fastest eq I know of. The short cuts are super fast and work on the controllers. No need for a mouse
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
HTML code is On
Shortcut critza macOS 2 04-30-2012 05:29 AM
Shortcut Key 4 pseradarian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-04-2009 05:13 PM
SHORTCUT HELP!!!! LuisB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-02-2007 06:45 AM
PT Shortcut budster Pro Tools TDM Systems (Mac) 2 12-03-2006 03:29 PM
Shortcut! Bookerv12 Pro Tools TDM Systems (Mac) 0 07-28-2004 07:08 AM
