Old 03-22-2018, 02:39 PM
Raoul23 Raoul23 is offline
Default Best way to find plugin that’s causing issues
Hi fellow TDM users, just wondered what’s the best way to find the plugin that is causing your sessions to crash/glitch.
I know we have the used and unused plugin folder but we have both TDM and AAX in PT10HD to deal with I lots of plugins and going one at a time would take ages. What practises are people doing? Moving all AAX to unused then concentrate on the TDM ones etc
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 03-22-2018, 07:09 PM
Default Re: Best way to find plugin that’s causing issues
My method:
1-Pick a session that crashes a lot and hold the SHIFT key while you open that session(all plugins will be inactive)
2-Using the modifier key, make a row of inserts active(start with slot A) and see if the session crashes. If it DOES, you narrowed it down to something in row A. If it doesn't crash, make the next row active and retest.
3-once you pin it down to something in a row, make that row inactive and then enable only stock plugins in that row(odds are that it will be a 3rd party plugin to blame)
4-make active the 3rd party plugins in that row, one at a time and hopefully, you will be able to nail the bugger
The next method is more work:
1-drag all 3rd party plugins out of the plugins folder(you can move them to a folder on the desktop as a handy place)
2-run a session that gives you fits and see if removing plugins helped.
3-start dragging small batches of plugins back into the Plugins folder until you figure out which is the bogus one(much more tedious than the first method)
Old 03-22-2018, 07:28 PM
Southsidemusic's Avatar
I would go with putting ALL plugins in the unused folder as PT can and do crash even if a certain problem plugin is Not in the session. Plugins can crash PT by just sitting in the plugin folder so put all of them in unused folder and then put back like 3-5 of them at a time until you find the problem plugin.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Is my Custom PC causing issues? kingofsnake Windows 4 03-29-2016 08:24 AM
SansAmp plugin causing CPU load issues (???) Ralf_T Windows 8 03-31-2015 02:52 AM
Automation Changes causing issues Vagrant Producer Windows 1 12-28-2012 02:34 PM
8.04 on xp causing plug in issues converted 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-10-2010 02:31 AM
Plugin Updater Causing Pro Tools to Not Run instro001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-17-2006 11:46 PM
