Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 03-12-2018, 01:20 PM
Drew Mazurek's Avatar
Default Re: Help Needed
Originally Posted by Tommys Daddy View Post
Any thoughts Drew? Thank you for your help!
Sent from my SM-J327T using Tapatalk
Yeah, trashing prefs would be next step.
A bit of a hassle, but till revert your rig to factory defaults and hopefully fix it.
www.drewmazurek.com
Old 03-12-2018, 01:30 PM
YYR123's Avatar
YYR123 YYR123 is offline
A screenshot of your Bounce Dialog might be some help
Daniel
Old 03-12-2018, 01:56 PM
Tommys Daddy Tommys Daddy is offline
I just purchased the Trasher app from the link you gave me. Hopefully that will work. Once it downloads does Trasher just reset everything to Factory defaults?
Old 03-12-2018, 02:00 PM
You decide what gets trashed.
www.drewmazurek.com
Old 03-12-2018, 02:04 PM
ok. so I should select I/O and reset them, I guess, right? Thanks for your help!
  #16
Old 03-12-2018, 05:02 PM
zedhed's Avatar
zedhed zedhed is offline
I was going to suggest defaulting I/O, so yes is the answer to your question.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Reamping help in PT 11 badly needed..... Kemper dudes needed!!! TheEdster75 Pro Tools 11 6 01-08-2017 08:38 PM
PT9 003 Help Needed Airspider23 Pro Tools 9 0 12-13-2012 11:34 PM
Help needed Please Hidden Sound Pro Tools TDM Systems (Mac) 4 09-28-2010 04:34 PM
help needed bryanpatrick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-06-2004 10:18 AM
Help needed!!! CHRS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-30-2003 08:59 AM
