Old 07-26-2009, 10:07 AM
PastaViking II PastaViking II is offline
Thumbs up Using Mainstage 2 to run AU softsynths inside ProTools - the ultimate NI fix?
While looking through Apple's news on Logic 9 it dawned on me that Mainstage 2 might be the solution many have been looking for to run AU softsynths reliably inside ProTools.
Since Mainstage 2 is Rewire compatible it can most probably stream into ProTools without problem.
Can someone confirm this?
PeeVee
Old 07-26-2009, 10:14 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Re: Using Mainstage 2 to run AU softsynths inside ProTools - the ultimate NI fix?
I'm doing the exact same thing with bidule and it works great. The main limitation is that rewire only allows audio to travel in to pro tools, so it's really only useful for VI's.
Old 07-26-2009, 11:19 AM
crizdee's Avatar
crizdee crizdee is offline
PeeVee
Tried it with L8/mainstage and it wouldn't work multi-timbre. started to use Logic 8 itself as a multi-timbre VI player, which works quite well, but still buggy with a few VI's
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-26-2009, 05:27 PM
JMDNYC JMDNYC is offline
Look into Vienna Ensemble Pro from VSL -- it promises greater flexability than MS 2. It should be released any day now. I'm using the current version (ve3), and it is very stable. It also has 16 stereo paths into PT that are NOT reliant upon rewire.
ProTools 8.0.3 and Windows 7 Ultimate hate me!!! cornhead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 05-13-2010 05:51 PM
Midi Modifiers inside Protools???? Dog BBQ MIDI 0 04-28-2010 08:46 AM
Which FREE softsynths and drums for ProTools? nicksorenson Pro Tools M-Powered (Win) 7 06-19-2009 07:53 AM
anyone using Stylus RMX inside ProTools LE 7.1 ? MixerGuy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-14-2006 11:47 PM
VSTi, emagic and other softsynths + ProTools ProToolsDude Pro Tools TDM Systems (Mac) 10 08-25-2002 01:05 AM
