Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 05-27-2019, 10:30 PM
MarcOFB MarcOFB is offline
Default Setup talkback with Digital Monitoring
Hi!
Does anyone know how to set up talkback when using digital monitoring?
Old 05-27-2019, 11:00 PM
Top Jimmy's Avatar
Default Re: Setup talkback with Digital Monitoring
Route a mic through an aux track in Pro Tools and use a talkback plugin like this one.
https://www.soundradix.com/products/muteomatic/
James Cadwallader
Old 05-27-2019, 11:01 PM
So no chance of using the s5 TB button?
Old 05-27-2019, 11:13 PM
Top Jimmy's Avatar
Not sure. I've not worked on the S5. I did work for years on a D-Control and what I did there was to take the talkback mic out from the Xmon and split it to an amp driving a squawkbox on the wall in the big room, and to channel 16 on an Aviom personal monitoring system. Turn the amp on and we could talk in the big room or leave it off and we only go out via the Aviom.
James Cadwallader
Old 05-28-2019, 06:34 AM
its2loud its2loud is offline
The talkback mic for the S6 is converted from analog to MADI. There’s no need for additional software from third parties.
Here’s the manual.
https://www.manualslib.com/manual/51...ack&selected=5
Old 05-28-2019, 06:38 AM
Here’s the manual.
Thank you so much. I take from this that i put my TB mic into channel 24 on my ml530 and then patch input 24 of the analog madi converter where the TB Mic is plugged in to mon D (my cue out)
Talkback Monitoring Question Siegfried Meier General Discussion 2 01-26-2009 05:14 PM
Does anyone know a way to setup a talkback mic... Allbaldo Pro Tools TDM Systems (Mac) 6 05-03-2006 03:23 PM
Control|24 talkback into 002R monitoring? stainless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-08-2005 05:33 AM
Help with talkback mic setup . . . Superclock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-31-2003 12:08 AM
Talkback Mic Setup SOwens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-11-2001 07:01 AM
