Old 08-12-2019, 12:51 AM
Kinh Kinh is offline
Default Is it possible to solo aux sends?
I just wanna hear the effected signal similarly to in Logic and Ableton. Can this be done in PTs?
Intel 6 Core i7-4930K CPU @ 3.40GHz
32GB DIMM DDR3 G.Skill
Samsung SSD 840 EVO
WD Black SATA 7200
ASUS SABERTOOTH X79
Windows 7 Ultimate 64
Mbox3 Pro Firewire 400
ProTools 10.3.8
ProTools 11.3.1
https://soundcloud.com/matthewcrowe
Old 08-12-2019, 07:20 AM
Benny_Cha_Cha Benny_Cha_Cha is offline
Default Re: Is it possible to solo aux sends?
Yes. Use the solo mode “AFL” or “PFL”. Stands for After-Fader listen or Pre-fader listen. You set the path for this separate path in the I/O window.
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
twitter // instagram // facebook // imdb
PT Ultimate 2018.7, Mac Pro 5,1 12-core 3.46, 24Gb RAM, Mac OSX 10.12.6fd, SSD boot drive, SSD sample drive,
Neve 8816, HD Native PCIe, Apogee DA-16X, Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 08-12-2019, 07:57 AM
You mean I have to create a new I/O path just for this?
Samsung SSD 840 EVO
WD Black SATA 7200
ASUS SABERTOOTH X79
ProTools 10.3.8
ProTools 11.3.1
Old 08-13-2019, 08:32 AM
I'll let Benny answer that, but here's what I do for this need:
Every track(track presets and session templates are awesome), I add a send(named "Solo Path") in the last slot. I set them all to -0, all are pre-fade and all are muted. They all feed a separate pair of outputs on my interface(DIGI003R here). When I want to "solo" a bus or aux track, I switch my monitor source(I use a Presonus central Station) to the "solo path" outs(the pair that are tied to the sends). I can Ctrl-click on any track's last send so I can listen to anything I want(regardless of how its fed).This works really well if you have a spare pair of outputs
Other methods involve using the "Solo Safe" option(Ctrl-click on a solo button and it will be heard when anything else is solo'd). Whether you Solo-Safe an AUX or the tracks feeding the AUX will depend on your needs and your routing. Another way to hear aux returns(like reverbs and delays) is to feed them with pre-fade sends(sure, post-fade is the usual for feeding effects, but rules can be bent or broken...
Old 08-13-2019, 01:07 PM
BScout BScout is offline
Assign not create. It's in the lower right corner of the I/O window
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 08-13-2019, 01:53 PM
henningaround henningaround is online now
It cannot be done and I'm missing it so much ...
A note to both workarounds mentioned above: you have to take into consideration that if you solo listen to an auxiliary track AFL/PFL or via a separate output to your monitor controller that this signal is not passing your master auxiliary anymore (or any other routing point inside Pro Tools). There are some more workarounds with VCAs and grouping solo/mute functions... But for me it's just to complex for stressful mixing challenges.
I just said goodbye to that feature when I moved from a console to in-the-box mixing.
Old 08-14-2019, 06:59 AM
Not quite sure where that is. Do you mean I/O set up..audition paths & default output bus? That's just for the output of my speakers so you probably dont mean that. Do you mean the 'output window button' of the mixer/'out' and choose a bus
Samsung SSD 840 EVO
WD Black SATA 7200
ASUS SABERTOOTH X79
ProTools 10.3.8
ProTools 11.3.1
Old 08-14-2019, 05:44 PM
Led Led is offline
The only sad roundabout way I do this is to highlight all the send tracks plus aux track, hit shift+alt+solo, which solos them all, then set the send tracks to 'no output'. Works ok with only a couple of send tracks, takes more clicking around for something like a whole kit, but you can highlight all send tracks and hold shift+option to change all their outputs at once. That way you are still hearing the aux return via any buss processing.
It's such a helpful thing to be able to solo aux returns for layering them eq wise, bit of an oversight imho.
Andy Evans
Sound Designer/Composer/Mixer
Melbourne, Australia
www.mud.net.au
Old 08-14-2019, 08:19 PM
It’s called “AFL/PFL Path” and it’s in the lower right of the “Output” pane. If it’s not there, then your version of PT doesn’t support AFL/PFL.
Ben Rubin
benrubin.com
Old 08-14-2019, 09:07 PM
Output tab
Can't Solo Tracks When Bussed To Aux Sends / Solo Safe is armed (Greyed Out) adrianrobison macOS 5 11-19-2014 05:09 PM
Solo does not use sends? Bill0287 Pro Tools M-Powered (Win) 6 02-03-2010 10:22 PM
solo mutes aux/hedphone sends jaimo ICON & C|24 2 04-22-2007 09:48 AM
Solo and Solo in Sends not coupled??? Andi R 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 07-20-2005 05:41 PM
A question about Aux sends, Midi channels and Solo chrispnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-17-2003 11:51 PM
