Old 01-31-2011, 02:15 PM
D K D K is offline
Default PT9 - Noobie inbound - Sorry!
Hey All,
PT9 just arrived today and I will begin the install process this evening.. Feel like i have been reading forever but just to make sure I have a couple of things correct:
1). I am installing on C2Q 6600 - Is it correct that I should only enable 3 cores for PT engine for better efficiency?
2) This will be my first time working with the RTAS plugin format (always used to VST). I am assuming that these cannot be in the same folder. The reason I ask is I use Novation Nocturn for plugin control and I believe it puts all "wrapped" plugins in the same folder - Is this a PT9 no-go?
Sorry for the "Freshman" questions - I'll get there..just need to get out of the gate...
Old 01-31-2011, 02:40 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: PT9 - Noobie inbound - Sorry!
Hi, welcome to the forum! All the plugins, RTAS and wrapped, go into the same folder: C:\Program Files(or Program Files (x86) for 64-bit Windows 7)\Common Files\Digidesign\DAE\Plugins. Of course, the vst plugins go into a directory of your choice - just the wrapped ones go into the above folder.
As far as using 3 or 4 cores for Pro Tools, sounds correct but I'm not positive. Mine shows up as 8 cores in Pro Tools and I have 7 enabled. I'm guessing the idea is to leave 1 open for other O/S functions.
Good luck with the install and enjoy!
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.6
Old 01-31-2011, 06:53 PM
D K D K is offline
Much appreciated..
Looking foward to my journey
Thanks
D
Port or Program rules for Outbound/Inbound connections for passing Windows 8 Firewall lehmann Artist Series 1 03-05-2014 03:17 PM
Pulled the trigger...11R inbound balance Eleven Rack 9 06-04-2011 11:09 PM
Noobie DeezTracks Pro Tools 9 3 11-11-2010 01:09 PM
Noobie question. kb420 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-27-2008 08:30 AM
Thoughts on an inbound OSX future Clubsoda Post - Surround - Video 1 09-23-2002 03:03 PM
