Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 02-06-2018, 11:36 PM
Kinh Kinh is offline
Default Mbox Pro keeps resetting
I have a bar fridge and whenever it goes off and audio is playing the Mbox resets. This has caused me great frustration when I'm in the middle of doing something to all of a sudden be interrupted by this and then have to switch the interface on and off again. Does anyone know why its doing this?
Iv'e tried running extension leads from different rooms, using powerboards with safety switches but it keeps doing it. The computer, monitor and every thing else doesn't reset just mbox.
Intel 6 Core i7-4930K CPU @ 3.40GHz
32GB DIMM DDR3 G.Skill
Samsung SSD 840 EVO
WD Black SATA 7200
ASUS SABERTOOTH X79
Windows 7 Ultimate 64
Mbox3 Pro Firewire 400
ProTools 10.3.8
ProTools 11.3.1
https://soundcloud.com/matthewcrowe
Old 02-07-2018, 07:07 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Mbox Pro keeps resetting
It sounds like you have a power issue, not an Mbox issue.. I'd look at a cheap UPS or at least a power conditioner: https://www.sweetwater.com/insync/po...ces-explained/
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 02-07-2018, 01:26 PM
UPS is the smartest money you will ever spend. Something like this:
https://www.ebay.com/itm/APC-by-Schn...UAAOSw8axaEHLG
Or bigger, and don't plug your speakers into it(because you don't need to).
BTW, the Mbox is firewire? Is it powered by the FW buss or do you have the separate power supply connected?
Old 02-07-2018, 09:08 PM
It's powered by the 9v DC at the back. This goes into a different power board than the computer which is in another room. I've put them in the same source but no difference. For some reason the firewire gets disconnected from computer for a slit second when the fridge goes on or off or sometimes if I turn the light on or off.
Samsung SSD 840 EVO
WD Black SATA 7200
ASUS SABERTOOTH X79
ProTools 10.3.8
ProTools 11.3.1
Old 02-08-2018, 12:21 PM
??? Not sure I follow? If the Mbox glitches when the fridge goes on, or you switch a light, then you have a serious power problem that should be looked at by a licensed electrician. The Mbox doesn't pull enough current to matter, so maybe you have an outlet or breaker with a loose screw, or a bad power strip(in any case, it could be a fire hazard). Beyond that, maybe get a small UPS(actually, I HIGHLY recommend having your computer, interface, and all external drives connected to a decent battery backup(APC models between $149 and 199 are good options). It can easily save your ASSets(it has for me on several occasions)
Resetting when stopping oneblood 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-28-2004 08:26 PM
Resetting 002 Hardware BenTerry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-19-2004 11:54 AM
Resetting a HUI? studiomusic Digidesign Hardware & Software 0 06-26-2003 01:14 PM
preroll resetting pkcraft 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-01-2002 05:13 AM
Buffer?CPU keeps resetting to 65%, why? H-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-01-2001 12:38 AM
