Crossfades distorting and export errors... Serious issue!
Kinda freaky situation: PT 12.4 HD Native on a Mac Pro Mac Pro (Late 2013) with 32GB memory OSX 10.11.2 running a 32bit 96kHz session on healthy SSD with plenty of space.
When I consolidate a crossfade between two tracks for a gap-less CD release, using e.g. hard in, I get distorted audio: The result: Surely there must be plenty of headroom withing the 32bit 96kHz domain and I have seen it happen before several years ago (see the tread here) but never got an answer. Even trying a different Audiosuite renders (EQ set to default, or DC offset removal) doesn't change a thing. Only recording it on a new track works. But what is even more disturbing, is when I have exported the files, crossfades are simply missing (although tracks are fully consolidated within PT) and even broken apart: the end of a track gets repeated on the start of the next. Just to make sure: I'm using a totally different system than back in the days, no cracked stuff, healthy system. When I cannot trust my exports to be *exactly* what I have in Pro Tools, I'm toast.... |
Re: Crossfades distorting and export errors... Serious issue!
Hi Arno,
I feel for you. A work around for you might be to render the crossfades on a new duuplicated playlist. To render, select the audio files and press opt-shift-3. This should render the fades at least. It might get you through your work for the day. Persoanally, I had to revert back to 11.3.2 because it was getting embarrassing to have things go astray with a client present. "Hobby" tools. |
Crossfades issue | TMMusic | Pro Tools 10 | 4 | 05-17-2017 09:19 AM |
Issue when consolidate or AudioSuite crossfades | Jperkins | Pro Tools 12 | 10 | 07-01-2015 01:46 PM |
PT 9 Export Track Issue | LeBandit | macOS | 1 | 02-10-2011 07:39 AM |
Weird errors on btd and export files | Bastiaan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 05-23-2005 03:36 PM |
File Export Errors | loomster | General Discussion | 0 | 03-13-2001 01:59 PM |
