Old 06-22-2012, 09:08 AM
anth anth is offline
Default automatic delay compensation question
Is the delay reading of a plugin in pro tools 10 still meant to be the same when ADC is on or should it be zero e.g. I have a lexicon reverb plugin that incurs a delay of 32 and when ADC it still says there is a delay of 32 in the track?
The reason I ask is because after lining up two tracks (seperate mics on a guitar cab) to sound good, when I have the plugin on one of the tracks (bypassed)... the alignment goes off (i.e. there is a delay between the tracks and I hear comb filtering effect). ADC should be compensating for this ? I tried setting the ADC to short and long and had the same problem.
Old 06-22-2012, 12:02 PM
nst7 nst7 is offline
Default Re: automatic delay compensation question
ADC can't change the built in delay of the plugin. All it does is delay the other tracks the same amount to match it.
Old 06-22-2012, 03:43 PM
Sounds like a good reason to put delay and reverb plugins on AUX tracks and send to them, keeping them set to 100% wet mix. That way you never combine dry signal from 2 tracks, avoiding any comb filtering.
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 06-22-2012, 05:39 PM
soybalm soybalm is offline
It's supposed to compensate for any inserted plugs as well so it should be bumping the other tracks back. Another thing is I find that with certain plugs, I have to completely take them out of the chain so there is no latency. If I just bypass, I still get the latency from the plug. If I remember right, one plug may have even caused a latency while in an inactive state!
Old 06-23-2012, 06:55 AM
Actually, most or all plugins will cause latency while bypassed(you would not want that to change if you automate the bypass). ADC is not quite perfect, and it only takes 1 sample to cause comb filtering between identical signals. I have never had an issue with 100% wet verbs and delays on AUX tracks
Automatic Delay Compensation question timeey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-12-2012 02:36 PM
Automatic Delay Compensation? Dax Xenos Pro Tools 9 15 06-06-2011 07:21 PM
Automatic Delay Compensation alfadog Pro Tools M-Powered (Win) 1 04-08-2006 08:53 PM
Automatic Delay Compensation stakeoutstudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-28-2005 02:02 PM
Automatic Delay Compensation slangification Pro Tools TDM Systems (Mac) 5 04-28-2004 12:02 PM
