Old 05-12-2011, 02:01 PM
Cal D Cal D is offline
Default Monitoring/Punch Question
I am using Fast Track Ultra with my set up.
Here is my question:
I have recorded a Vocal on Track 1
I set my pre-roll and post roll, in order to punch into Track 1, to correct one part of the vocal.
However, to have the singer hear his vocal just prior to the punch in point, i have to do the following:
Slide up the Track 1 slider in the mix window, so that the singer can hear his vocal in the phones.
Quickly pull down the slider all the way, so that the singer only hears his punch, during the punch in portion.
The problem is, if I leave the track slider up during the punch, the singer hears what sounds like a doubling of his voice, which throws him off.
The reason this is a problem, is that I have to quickly move the slider up and then down during this process. Having to do this with the mouse is a pain.
Is there any way to not have the singer hear his voice double, during the actual punch - while leaving the slider up?
Thank-you
Old 05-12-2011, 02:13 PM
soundsurfr soundsurfr is offline
Default Re: Monitoring/Punch Question
Thank-you
Select the track. Go into the TRACK pulldown menu, select Auto Input Monitoring. The vocalist should hear his original track up to the punch point, then his live vocal while in record mode. No need to mess with faders.
Soundsurfr
MAC Mini, 2.3GHz dual-core i5, 8GB DDR3, 500GB Hard drive, 288MB DDR3 SD RAM
M-Audio Firewire 1814
Yosemite OS
Old 05-12-2011, 02:37 PM
soundsurfr
That would save me a lot of grief. Thanks for the answer.
Punch-in: How are you getting around monitoring issues? graveleye Windows 6 05-14-2013 09:33 AM
Monitoring track before punch in Jerry James macOS 5 04-05-2012 06:57 PM
punch in monitoring problem brian crain Tips & Tricks 2 10-30-2010 08:58 PM
Punch in monitoring problem HBryant 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-02-2010 04:54 PM
Feedback when monitoring punch in earsmiles Digidesign Hardware & Software 2 12-06-2000 08:26 AM
