Old 10-25-2018, 11:07 AM
MusicMadness MusicMadness is offline
Default Re: Command8 faders
There's one more issue appeared after I cleaned my faders. It happens sometimes that Opt+touch one fader affects another one on channels 1 and 2. Any ideas where should I look for solution? I tried to track down whole path and couldn't figure it out. I swapped faders 2 and 3 and problem still occurs on ch 1 and 2.
PT HD 2018.1, Mac Pro 2013, Digidesign Command 8, Focusrite Clarett 2Pre
Old 10-25-2018, 11:32 AM
YYR123's Avatar
YYR123 YYR123 is online now
Default Command8 faders
That opt fader trick is related to the Capacitance Touch feature of the fader.
I would suspect grounding issues either with you wall outlets or your chair space floor area
Also could be a grounding issue inside of that unit
Daniel
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 09:56 PM
Command8 Control 24 faders question Dot Pro Tools 9 4 09-28-2011 06:20 PM
Custom Faders moves position of all other faders!?! freeBase ICON & C|24 5 02-26-2009 06:44 PM
Command8 Faders don't follow MIDI track automation highcard ProControl, Control|24, Command|8 1 12-19-2006 11:34 AM
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... domsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2004 07:06 PM
