Old 11-01-2015, 03:05 PM
zerothrills zerothrills is offline
Default 'The Video Engine reported and error' message when trying to play any video
Just purchased ProTools 12 and on my laptop any videos will playback fine. But when I try the same project or a new video imported in on my desktop I get that error message when it tries to play:
'The Video Engine reported and error. More information is in the Video Engine log file.'
Not sure where that log file is saved but perhaps AVID support could have a look at it.
Thanks!
Old 11-26-2015, 01:19 AM
HDXSound HDXSound is offline
Default Re: 'The Video Engine reported and error' message when trying to play any video
+1
Old 11-26-2015, 07:57 AM
darbyclash34 darbyclash34 is offline
Just something to try, as I'm having a different but somewhat similar issue. Try opening Pro Tools and creating a new blank session, let it finish creating the session, then press play and let it run for a few seconds. Also, go into your playback engine and make sure you've got the video engine enabled. Everything cool so far? If so, try opening the session that's giving you trouble and see if it works correctly. If it does, please report back, as I'm having to create a new session every time my interface has been power cycled, or I get either a video or an audio engine error. I've done every bit of troubleshooting both Antelope Audio and Avid can give me, and at this point it appears to be a bug in Pro Tools, but seemingly pretty rare.
Hope that helps!
Old 09-29-2016, 01:55 PM
bifbangpow bifbangpow is offline
It's a pretty huge bug for the industry standard software... I mean, if nothing can be done, then all of us composers have to switch to a different DAW. Come on Pro tools; fix this.
my specs:
iMac 2020
3.8Ghz 8-core Intel core i7 processor
Catalina OS
ProTools 2020.12
Scarlett Focusrite
+ Saving to External Harddrive
http://MayMcDonoughMusic.com
Old 10-03-2017, 06:40 PM
Aser Aser is offline
+1 on the error, also seen others while surfing the internet to solve this problem
Old 10-04-2017, 01:05 PM
Eric Lambert's Avatar
The video error issue is much worse in 12.8.1 than in 12.8.0. That's been the case for each of our studios that have upgraded to 12.8.1. Sessions with video have become practically unproductive.
Old 03-16-2019, 01:26 AM
belasoul belasoul is offline
Had a similar issue after power cycling my aja t-tap. Problem was that PT took the Aja as playback device instead of audio interface.
Béla Brandes | www.bbsounddesign.de
Old 05-06-2019, 10:33 AM
paulmitch paulmitch is offline
Has anyone come up with anything for video playback? I've had a beast of a time trying to play back for SFX.
Home:
27" iMac, (Retina 5k, 2017)
4.2GHz Intel Core i7, 32 GB RAM
OSX 10.3.3
UAD Apollo 8 Duo
UAD Apollo 16 silverface
UAD Satellite Octo, Thunderbolt
PT 2018.10
Work:
Mac Pro (Mid 2012)
2x3.06GHz 6-Core Xeon, 32 GB 1333 MHz DDR3
OSX 10.13.6
Avid HDX HD Madi x 3
SSL C100
Old 05-16-2019, 07:47 PM
musicelect musicelect is offline
I had issues with the video engine as well. I saw both the slow loading bar and some hard spinning beach balls where ProTools would freeze while trying to load the video engine.
Looking around here on the DUC, some people mentioned interference with other video drivers. I had some AJA stuff installed that I didn't need anymore. AJA has an uninstaller app that completely removed everything and after a restart, the ProTools video engine works perfectly.
Hopefully this helps you.
www.markproaudio.com
Old 12-08-2019, 10:37 PM
espantalho1 espantalho1 is offline
+1 I get this error too.
Video Engine Error aptmusic9 Pro Tools 11 7 03-10-2017 01:55 PM
Pro Tools 12 Video Engine Reported an Error Justin Viscuna Pro Tools 12 0 08-19-2015 02:13 AM
Video Engine not working.. crashing when i load in a video to PT11 sarahsherlock Pro Tools 11 5 08-16-2014 12:35 AM
Video Engine Error (and log?) Farmer Dave Pro Tools 11 2 12-07-2013 09:15 PM
"video engine failed to initialize" message fuzzles Pro Tools TDM Systems (Mac) 2 10-29-2006 11:16 AM
