Old 04-01-2012, 11:44 AM
bilug bilug is offline
Default Drum machine won't trigger
I'm running mac 10.4 with PT 6.9LE
I'm new to midi...
I've got an Alesis SR16 hooked into my computer and I'm able to get midi recorded onto a midi track.
But when I play back....nothing!!! Shouldn't this trigger the drum machine sounds? I have the SR16 slaved and it begins playing when I hit play on PT, but no sounds.
What am I doing wrong?
Old 04-01-2012, 07:05 PM
flommer flommer is offline
Default Re: Drum machine won't trigger
Do you have audio cables connecting the SR to your protools interface?
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 04-02-2012, 07:16 PM
Yes, I also have the audio cables hooked to the mbox. I am able to set up a midi and audio track and hit record on both tracks and see midi/waveforms recording.
When I play back just the midi I get nothing.
Old 04-02-2012, 08:18 PM
Check the Rx channel in your SR16... it's probably set to channel 10
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-03-2012, 03:01 PM
It is set to channel 1
Old 04-03-2012, 11:25 PM
From the manual's troubleshooting section:
SR-16 not receiving MIDI notes.
SR-16 "Drum In" turned off. - Turn it on.
Incorrect MIDI channel. - Set channel accordingly.
Incorrect drum note assignments. - Set drum notes accordingly
I have an SR-16, but I absolutely despise it so I have only ever connected it to ProTools once or twice (so I know it is possible). If you continue to have problems I might dig it out and see what the deal is... but I really hope you can get it to work so I don't have to.
You should take a look at the manual if you don't have it.. Do a google search for "alesis sr 16 user manual" and about 2-3 links down will be a pdf from zzounds
Old 04-05-2012, 02:34 PM
I have the manual and followed the directions. it wasn't clear on what channel to set it to....
I have it set to DRUM IN - OMNI
DRUM OUT - CH1
All I see on the midi track is the notes that have little X's on them.
Old 04-08-2012, 06:22 PM
Well I am another step closer...I was able to get the midi to make the drum machine fire finally. DRUM OUT was set to OFF somehow...not sure how I missed that!!
Anyway...now it records and plays back!
Next problem...everytime I hit play on PT it starts the drum machine up...so I have to hit STOP on the drum machine, then continue listening to the midi send the triggers. Where is the setting that stops controlling the drum machine??!!
boss/roland/hardware etc..Drum machine as midi controller/trigger into eleven rack yellow Eleven Rack 5 09-30-2013 12:30 PM
Using protools midi to trigger a drum machine help Dr Scary 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-23-2010 10:04 PM
Using Drum Machine To Trigger BFD Rambo66 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-31-2006 11:56 PM
Drum Trigger thegoodone Pro Tools M-Powered (Win) 1 12-14-2005 07:35 AM
spd 20 drum trigger ethical MIDI 0 11-05-2001 07:30 PM
