Repositioning Multiple Keyframes Vertically ...
I can move a selected group of keyframes backward or forward in time by way of nudging.
Is it possible to perform the same function with relative amplitude? In other words - repositioning multiple selected keyframes verticially? As a basic example lets say I have 3 keyframes used to create a linear fade. I want to retain their relative relationship while repositioning all three keyframes verticially (affecting amplitude) as opposed to horizontally. thx. -paul. |
Re: Repositioning Multiple Keyframes Vertically ...
What is a "keyframe" in Pro Tools ? (I am German)
Do you talk about nudging volume automation / clip gain ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
thx. -paul. |
Yes
The nodes you are referring to can be moved forward and back w nudge or select a few and then drag your mouse (when using the trim tool) up when looking at the volume automation and now your changing the amplitude of all selected nodes EDIT: Oh, are you asking if you can set that to a specific number like you can change the nudge value?
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer |
Is there a keyboard shortcut to nudge selected animation points vertically? And lastly (in response to your edit) - it would be great to be able to set a speciific amplitude value. Is it possible? Again, thanks. -paul. |
I have never tried to even see if there is a way to set a certain level when adjusting automation... I think you can snap it to "0" but I dont think you can make it work like nudge does in that fashion... to me its not a big deal cause I can see how much volume Im lifting or lowering them while you move the mouse... In MOST cases I usually write the automation with a motorized fader and if I dont like it I redo it... but thats just how I prefer to do it. Sometimes using exact #'s (like always jumping 3db for example) doesn't calculate in audio mixing... but hey everyone has their own thing...
(And it is not called animation points but automation breakpoints.) Quote:
click/highlight the volume number, type exact number, enter.
Thanks you guys for the help.
-paul. |
Nudge automation vertically? | the hecksome | Tips & Tricks | 4 | 08-26-2014 07:22 PM |
Add Keyframes no problem - but how to REMOVE? | guylarge | Pro Tools M-Powered (Win) | 0 | 01-03-2010 02:29 AM |
Tutorials on altering volume over time? Keyframes? | Mark Turner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-04-2009 06:02 PM |
external drive - horizontally, vertically? | Andi R | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-10-2005 06:56 PM |
Zooming vertically? | Burton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-27-2001 01:29 PM |
