Output needs toggling every time you want to hear it - Anyone else?
Weird -
For a little while, now, PT 12 (now 12.7) is all like "NOPE" when I want to hear the output from a track I am recording into (eg I like to monitor my outboard verb as I am recording to check how it sounds), until I manually select a different (ie WRONG) output and then select the correct one again - then it's if it never was a problem. I have to do this pretty much every session. Toggle the wrong one, then the right one. It's like the process of selecting a different output (from within the channel) and then toggling back to the correct one is now necessary to prompt PT's demented mind - "oh, yeah, that's right, that IS the correct output, after all". Screen Shot 2017-01-29 at 2.02.18 pm.jpg It's driving me nuts. Anyone else with this prob? |
Re: Output needs toggling every time you want to hear it - Anyone else?
Generic advice/questions:
Try trashing prefs Does this only happen with one session? Or all your session? What interface are you using? If you try a different interface (like Built-In Output on a Mac) does this happen? If this was hitting lots of users DUC would be full of complaints. The track you are showing the output for is solo'ed but does not have track monitoring enabled. Were you just showing us what is available in the output selector or is that track one specifically having the problem? Last edited by Darryl Ramm; 01-28-2017 at 08:17 PM. |
All sessions.
Digi 003R. I'll have to try my built in output... I was only showing what is available and illustrating what parts of the UI I was referring to. I am loathe to trash prefs because I only literally just resolved a constant -6101 CPU error with Avid's help - took ages and many, many installs / reinstalls / trash / reinstall etc to fix. It took hours worth of work. I'm not touching my prefs. If that's the issue, which it may be, then I'll just keep dealing with it. I'd rather work with this than risk having -6101's kill all my work again.... Thanks! |
Trashing prefs should not cause problems.
Installing 12.7 should not have caused problems, yet it still caused -6101 errors all over the place.
system info ??
Trashing prefs is something you should often just try when facing problems. Trashing prefs makes no sense to compare to doing a Pro Tools upgrade. There are things there that commonly cause problems, including plugin and OS compatibility issues. Trashing prefs is commonly used to fix problems. And it's easy to do and if it does not help then move onto the next troubleshooting step. |
I'll give it a go, I'm just wary.....
Watch this space... |
Mac or PC at least would help !!!
Sorry!
My bad. I just created an informative signature but it isn't retroactive - 2015 iMac Sierra 10.12 Digi 003R I will do a backup and see if trashing prefs solves the issue....
PT 2022.10.0 2017 iMac Pro SSD 32GB 2666 MHz DDR4 External SSD Monterey 12.6.1 Presonus Quantum 2 (Thunderbolt) |
Quick key for toggling time i.e. Bars|Beats & Timecode? | Eric Lambert | Pro Tools 11 | 4 | 04-25-2014 02:08 PM |
Cannot Hear Output | Chief Technician | Pro Tools 9 | 1 | 11-28-2012 04:06 PM |
192 output Dither.. output to Hear System | Jeff E | Pro Tools TDM Systems (Mac) | 10 | 07-22-2009 10:41 AM |
Cant hear output | omons2273 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-16-2007 06:46 PM |
Cant hear output | omons2273 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-16-2007 06:08 PM |
