Old 03-27-2016, 08:03 AM
redmount redmount is offline
Default Control surface : Mix + Virtual Inst control (PT12 HD)
Hello,
what control surface would you recommend for "live" virtual intruments tweaking (Omnisphere 2 for example)...
Was starting, then stopped, considering Novation SL MkII series, until I found that AAX plug ins were not supported...
I would love to find a compact block of faders + rotating knobs + maybe a little keyboard - 2 octaves, to control mixing in PT 12 and have access to VI modulations controls.
Thanks for your help
Raf
Old 03-27-2016, 09:33 AM
Default Re: Control surface : Mix + Virtual Inst control (PT12 HD)
Originally Posted by redmount View Post
Hello,
Raf
Something to keep in mind is whether the faders are motorized or not. This makes a difference especially during mixing because if they're not then whenever you move a fader levels will jump to whatever the fader is at at the time. UNLESS the software driver for the controller only makes a level change when the controller fader reaches the point where the fader level is in PT (or whatever daw software you're using. Automap control functioning is a crapshoot at best.
Jack
QAPLA!
Old 03-27-2016, 11:25 AM
Thanks for this...
So, is the Avid Artist series THE go to option ?
Old 03-28-2016, 05:25 AM
Thanks for this...
Not really. Besides they don't have a music keyboard. If you want that in the equation then you're limited. If you can skip that then there's a couple of Behringer units that seem pretty good. And which one you get depends on how much a priority vi control is.
If having a keyboard is a necessity take a look at Arturia's Keylab series.
Jack
QAPLA!
Old 03-30-2016, 02:42 PM
Thanks for this... keyboard is absolutely not needed. Already have a 88notes kb. Main purpose is to control multiple VI parameters live. I'll check the Behringer options
Cheers
Raf
MIDI Track Fader Used as a Virtual Control Surface? Kincavel Pro Tools 12 0 03-09-2016 08:21 PM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
D-Control Es32 Control Surface No Sound from Headphone outputs mark007 Pro Tools TDM Systems (Mac) 0 02-08-2012 07:03 PM
Virtual Midi Control Surface - Is there any? Nomad76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-22-2010 09:47 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
