Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Win)
Old 04-16-2013, 10:14 AM
Space Firebird Space Firebird is offline
Default Mbox 3 - Connecting Hardware Synth Module and Axiom 25 Keyboard Controller
Hi, I'm trying to get my head around setting up my MIDI studio for the first time.
I have a Roland U220 synth module and and Axiom 25 Keyboard.
I would like to use the Axiom to record MIDI data, playing the sounds from the U220.
Could someone please describe the connections?
Do I connect the U220 (via MIDI) to the Mbox 3, or to the Axiom?
Do I connect the Axiom to USB as I have been doing for virtual instruments (and would prefer), or to the Mbox 3 via MIDI?
After I have physical connections, how do I then set up my MIDI studio so that it sees everything?
Old 04-16-2013, 11:36 AM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Default Re: Mbox 3 - Connecting Hardware Synth Module and Axiom 25 Keyboard Controller
This is what it says in my Axiom Pro User Guide:
Page 12
Connection Diagram
Hosted Mode:
When using Axiom Pro with a computer:
  • Connect Axiom Pro to your computer using the supplied USB cable.
  • If you own sustain or expression pedals, connect them to the “Sustain” and “Expr” inputs on the back of the keyboard.
  • If you would like to connect Axiom Pro to an external MIDI-capable device (such as a synthesizer, sound module, etc.), connect the MIDI output port to the external device’s MIDI input, while connecting the MIDI input port of Axiom Pro to the external device’s MIDI output port.
I would assume it would be the same for the regular Axiom as it is for the Axiom Pro.
Definitely I would use the USB MIDI connection rather than the Mbox MIDI I/O for the Axiom. And I would start with the synth module connected to the Axiom.
Bruce Paine
System Details
Old 04-16-2013, 08:14 PM
Thanks, that worked!
I've got the hardware set up, I'll try asking about the routing in the software forum.
M-Audio Axiom 49 Keyboard connecting to Pro Tools 9? JWhole MIDI 7 10-04-2014 11:08 AM
Connecting a Synth Module to Protools Antech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-22-2010 03:50 PM
keyboard hum when controller cabled to sound module Jepse MIDI 2 07-08-2003 04:04 PM
connecting synth & module to 001 j old school 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-17-2002 12:58 AM
use the controller keyboard as a tone module too, or just as controller? Joseph Anderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-08-2002 12:01 AM
