Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Win)
Old 04-15-2013, 10:52 AM
edshoe edshoe is offline
Default Mbox Pro Sample Rate Selections Above 48 in Mode
Hello All - I'm an Avid noob, having just migrated my system from a motu2408/Cubase based system to Mbox Pro/Pro Tools 10.
I am attempting to select sample rates above 44/48 in hosted mode. However when attempting to select 96 (for example) from the sample rate selection drop-down, it will automatically revert to 44 or 48. The app is set to internal clock.
I have attempted this from the control panel within Pro Tools and with only the Mbox app open, and also with the host control turned on and off. Same results in all contexts.
I have scoured the manual and other available resources and still can't seem to find an answer. Mbox will run with higher sample rates in Standalone Mode.
Can anyone kindly tell me what I'm missing here or point me in the right direction. Any help would be greatly appreciated.
Old 04-15-2013, 10:55 AM
Default Re: Mbox Pro Sample Rate Selections Above 48 in Mode
FYI... I'm running on Windows 7 Ultimate 64-bit, Core i5 with 16 gig RAM
Old 04-15-2013, 03:45 PM
Emcha_audio's Avatar
When you create a session in pro tools, do you choose the 96 khz sampler rate? You're mbox should synched to your pro tools session when it's created.
Manny.
#BOYCOTTTUSPRODUCTS
just not Pro tools and compatible plugins...
Old 04-15-2013, 04:01 PM
Thanks for the reply Manny.
This issue is now RESOLVED.
I was using a Belkin Firewire card instead of a firewire connection directly to the motherboard. By switching to the native mobo 1394 connection, I am now able to use all sampling rates in all contexts.
Thanks again for the reply.
Ed
Registered User of:
Pro Tools 10
Pro Tools Mbox Pro
Avid Artist Control
Avid Artist Mix
System:
3.30 gigahertz Intel Core i5-2500K
Multi-core (4 total)
O/S:
PT LE 8 Mbox 3 Pro sample rate help. benherron.rrr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-20-2010 01:35 PM
MBox 3 Pro In PT9 Sample Rate cybrgost Pro Tools 9 4 12-04-2010 08:25 PM
MBox 3 sample rate Draulym Pro Tools 9 5 12-02-2010 07:36 PM
MBox Micro Sample Max Sample Rate Only 48 kHz? Joe Sciacca 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-07-2008 12:52 PM
Correct ADAT sync mode and sample rate? Stenjy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-23-1999 11:48 AM
