Help - MBox Pro misbehaving after updates
I have an MBox 3 Pro which I purchased from the local dealer in January 2012. It worked fine for the first twelve months or so.
A couple of months ago I downloaded the 1.0.19 driver update and installed it after uninstalling the old version which was delivered with the MBox Pro. On restarting the PC nothing worked and it could not be seen in the device manager. I could not get it to work at all. Restarting the PC and MBox did not work and restarting the MBox monitor service did not work. I removed the new driver and reinstalled the original driver. The interface came back to life but worked only intermittently and I noticed that the firmware was still 1.03 (not sure what the original was, 1.02 I think). As a last resort I downloaded the 1.0.19 driver again making sure the first copy was overwritten. I installed the new drivers and the box came back to life, worked for five minutes and then disconnected itself with similar results - nothing I did could make it work. The next time I started the PC, a day later, lo and behold it worked again and remained working for some time (> 1 hour) and then disconnected itself and once again could not be revived. Sometimes it will work without stopping and other times I have to turn off the MBox Pro, leave it off for a while and turn it back on. Very rarely, restarting the MBox Monitor service works. I have made sure that all the latest drivers are installed for graphics and Firewire. Any ideas welcome.
pfirkin AMD PhenomII X6 1100T 3.72GHz, Gigabyte GA-990FXA-UD3, Award OEM F2 05/17/2011, 8GB Kingston DDR3 1600, Nvidia GEForce GTX560, 1TB RAID1, Win7 Ultimate 64bit SP1 |
Re: Help - MBox Pro misbehaving after updates
Have you gone through all the suggestions in the Optimization guide? Make sure your USB ports aren't being put to sleep - I think this is in the guide as well.
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Thanks Joel
I have been through the optimizations before posting but I went through again as you suggested to be sure. I have only found one thing I had not done which was set the display screen saver to never. All the other sleep options were set to never. After restarting, the usual. It worked for a few minutes and now nothing. I have previously tried to run all applications in the background but all this did was slow things down without improving the MBox' behaviour so I still let apps run normally. As this machine is reasonably powerful I thought it should not matter. Also the network drivers are the latest. I am using a DLink USB WiFi unit DWA125. I am at a loss as this setup worked well for the first 12 months without my having to do anything. Any further suggestions gratefully received pfirkin
Never perform ANY update without a backup plan!
The problem is that Avid has admitted that the firmware updates have been glitchy. I sent mine in and it is now flawless. It is a drag to not have the Mbox for a few weeks but well worth the fix.
Sent from my Pro Tools beating heart.
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
I'm surprised the firmware updates wouldn't be included in the driver installs. I cant imagine AVID wanting to ship every Mbox back and forth every time there is a firmware update.
Joel
Thanks All
It looks as if I will have to send the box in, something I was trying to avoid because U will be without it for some time. Regards
There was a problem in those mboxes that had multiple firmware updates over time; I just wanted the path of quickness and opted to send in to avid.
Jryser, are DSP fx working properly after having the unit fixed?
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ |
misbehaving 003 please help | littlemoley | Pro Tools 9 | 4 | 08-04-2011 10:26 AM |
TL Rehab misbehaving in 8.1 | crizdee | Pro Tools TDM Systems (Mac) | 2 | 08-26-2010 11:40 PM |
002 misbehaving on 10.5.7 | topperf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-11-2009 05:20 PM |
SampleTank is misbehaving | LiamSlack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 04-10-2008 08:57 AM |
002r Misbehaving | mfb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-27-2007 01:03 PM |
