Old 10-14-2016, 07:14 PM
vudoo vudoo is offline
Default Xmon static build up
I'm getting a strange static noise from the Xmon, well i assume it's from the Xmon and not PT as i'm having the same problem when using other DAW that's also connected to the Xmon via Rednet 2, 5 and PCIe.
Everything is fine then suddenly i get sparse static that would build up over time.
Anyone seen this problem before ?
Old 10-18-2016, 09:17 AM
creativecontrol's Avatar
Default Re: Xmon static build up
Greetings,
How would you characterize the sound you are hearing? Does it happen on any of the 6 different inputs (Main, Surround Stereo 1-4) coming into XMON? With that said, is it present in all of the speaker outputs, engineer headphones, etc?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
New Build Review! Based on Mano/Ame? and SPCR Fanless build Calipoop Windows 4 11-16-2011 09:38 PM
PT just does not work, so should I build a new PC build or just but a MAC? ajcsound Windows 17 05-17-2011 10:22 PM
To build or not to build? Money is the question... storm-01 Tips & Tricks 5 09-23-2003 01:08 PM
To build or not to build? Money is the question... storm-01 Pro Tools TDM Systems (Mac) 12 09-19-2003 07:40 PM
To build or not to build? Money is the question... storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-18-2003 09:13 PM
