Old 10-31-2019, 11:04 AM
Thenewexhibit Thenewexhibit is offline
Default Fill gaps with midi??
Is there a way to change the midi note duration to basically fill the gap until the next midi note? I know I can manually do it, but I figured (and would assume?) there is an automatic command of some sort that takes the guess work out of it?
I converted audio to midi with melodyne for a bass guitar track to change the tone, and there are a handful of gaps, but I want to keep the timing and not meticulously zoom in to every gap and make sure they're lined up. Any easy automatic way? I feel Like I've found it before, but can't right now.
Thanks, and God bless!
Mike.
Old 10-31-2019, 12:41 PM
cmbourget's Avatar
cmbourget cmbourget is offline
Default Re: Fill gaps with midi??
Mike.
Properties in real time or quantize (atl-3). Legato / overlap.
  • Pro Tools 2023.12 Studio, Nuendo 12, Samplitude Suite Pro X7, Wavelab 11, Dorico Pro 5, Melodyne studio 5.
  • Apollo X 16 and 7.1.4 studio (Focal Solo6 be, Sub, and Focal EVO)
  • Softube Console 1. UAD systems (USB3).
  • Mac Studio M2 Ultra 2023. 2T. 128 Go. + 2X 4 T NVMe ext.
  • AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz 64 Go, full SSD
  • Roland V-Piano, Novation 88
  • Etc.
  • www.claudemarcbourget.com
Old 11-04-2019, 03:55 PM
Thanks! I'm still trying to figure it out actually.. I want to fill the gaps to the next note. All the notes aren't on a grid, and they aren't all the same note. How would I do that? Overlap makes them all overlap each other which is not what I'm looking to do, but just have the tails of the notes extend until the start of the next note.
Old 11-04-2019, 04:47 PM
cmbourget's Avatar
Difficult for me at a distance. But it's a game you need to know and master. It is a coordination between quantification and legato. Not everything is possible, but a lot is possible. You have to venture into Pro Tools' MIDI capabilities, which is better than its reputation. The solution goes beyond the specific case. You must master the functions. It's a good thing for the rest of your work.
  • Etc.
Randomise Midi without leavings gaps nwarren1981 macOS 5 11-08-2018 02:35 PM
Key Command for "Fill gaps and cross fade" Drywsef Pro Tools 12 7 10-08-2017 04:03 PM
Gaps when recording...used to have no gaps..how do I fix this? rexdigital macOS 4 11-11-2014 08:55 AM
Midi export creating note overlaps + gaps tombliss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-18-2010 10:13 AM
Shortcuts to fill gaps. ndaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-09-2006 02:52 PM
