can mbox 2 replace mbox micro?
I have mbox micor v 8 working on my mac pro snow leopard. I also have an mbox 2 v 7.3. on my G4 laptop. Is there any way to get my mbox 2 to be the hardware for my PT micro 8?
I was thinking of installing 7.3 on the mac pro. Is 7.3 supported on snow leopard and Can I have 7.3 and 8 installed on the same computer? |
Re: can mbox 2 replace mbox micro?
No, 7.3 will not work on SL. No you can not have 2 versions of PT installed on the same system disk. You can have 2 different system partitions, each with the correct OS and PT versions installed so each would work. I, personally, am going to install SL as soon as I pick up a new SATA drive and try 8.0.3 on it, but I intend to leave my current 10.5.8/8.0.1 installation untouched.
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Thanks Flommer for your help. I tried to launch my PT 8 with mbox 2 and it asks me to check to see if my hardware is on. 8 launches with my micro but doesn't see the mbox 2. I also tried have both mbox 2 and micro plugged in and went to the IO set up, but only sees the micro.
could it be my micro license won't see the mbox 2? any thoughts ? |
I'm guessing he may mean a MAudio Micro and not a Digidesign Mbox2 Micro. If thats the case the answer is no.
The MBox2, NMBox2 Mini and Micro all require PTLE to run were as the MAudio Micro needs Pro Tools MPowered or Pro Tools Essential. I think (but am not positive) that a MAudio Micro may only run with Mpowered 8.0 or higher.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
sorry both are digidesign. PT mbox 2 and PT mbox mirco
Maybe try deleting prefs and databases? (per the troubleshooting thread) Have you installed the 8.0.3 update? I'm not sure what else could cause the problem.. Is the Mbox 2 control panel installed in your OSX system preferences? Maybe there is something in there that needs to be set...
yes I have 8.0.3.
what prefs would I need to delete? I don't have any mbox 2 control panel installed. how would I install it? |
http://duc.digidesign.com/showthread.php?t=54888 As far as the control panel, well I'm not sure. You know where I mean, in the Mac OS System preferences like where your mouse and keyboard and user preferences are? The Mbox control panel shows up at the bottom with the miscellaneous stuff. I know it got installed on my system even though I don't have an Mbox...
ok, I see two control panels in my system prefs. mbox2 and mbox 2 pro. the mbox 2 pro panel doesn't see anything connected to it, but the mbox 2 panel sees the mbox micro but not the mbox 2 I have plugged in. I'll read your post and try and delete the prefs.
As flommer said, it should work. I switch between my Mbox2Micro to Mbx2Micro to Digi002 to Digi002R all the time on three different Macs and four different Windows PC's.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Weird sound in Mbox 2 & Mbox Micro | linderefter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-06-2013 03:22 PM |
:confused: Pro Tools HD playback thru Mbox/Mbox Micro? | JazzBum | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-06-2010 07:27 PM |
What should I replace my original Mbox with? | danackerman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-02-2010 03:38 PM |
Can I use MBox 2 Micro and MBox 2 with same PT8 Install? | taylor4814 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-16-2009 10:15 PM |
mbox micro + mbox 1 + software compatibility question | driches | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-15-2008 08:29 PM |
