Old 04-19-2015, 03:20 AM
Stereo Missile Stereo Missile is offline
Default Using other ethernet port for internet
Hi guys,
Since installing my S6 I've unplugged my studio computer from the internet. I had it plugged in to my internet router using the other ethernet port on my Mac Pro, but I found that having the S6 plugged in to one port and internet on the other tended to make the S6 performance a bit unstable. Just wondering if others have had the same experience, or if any of you have this working well? I haven't tried it since the earlier versions of the S6 software or WSControl apps, so I wonder if it is working better now?
Thanks!
Steve Peach
Stereo Missile Recordings
Creative Director - Red Note Visionary Sounds: http://rednote.com.au
Label: http://www.stereomissile.com/
Music Production / Mixing: http://www.stereomissile.com/musicproducer/
Mastering: http://www.stereomissile.com/mastering/
Old 04-19-2015, 05:23 AM
rcutz rcutz is offline
Default Re: Using other ethernet port for internet
I never testes mine that way.
I allways use both port, also because i work with a server so I need the other port to mount my disc's etc... I can't tell you but I never fell
Like the ethernet traffic would be a problem. i'm on mac os 10.8.5; pt 11.3.1; mac pro 3,1 (migrating to 6,1)
Ricardo Cutz
Re-recording mixer/sound editor supervisor.
Http://106db.com.br
Old 04-19-2015, 05:44 AM
tamasdragon tamasdragon is offline
I don't know what would happen if I use the second port for internet access, but we use one port for internal studio network (like Isis) and the other port for the S6 and it's all fine, rock solid. Never had an issue with it.
my blog:Tamas Dragon
Old 04-19-2015, 07:05 AM
Hmmm, ok thanks guys. Maybe it's time for me to revisit this and try it again. Are you setting fixed IP addresses? I didn't try that yet, just left it on dynamic. Maybe that's the issue.
Steve Peach
Old 04-19-2015, 08:07 AM
Brandonx1 Brandonx1 is offline
I use one port for the studio network/Internet and the other port for s6. Seems fine.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 04-19-2015, 08:44 AM
lucienpalmer lucienpalmer is offline
With Eucon and the Artist series, I had to use port one for Eucon and port two for internet. That solved quite a few weird connection issues. It was a known trick for the Artist series. When I got my S6, I did the same thing. No problems here at here.
Old 04-19-2015, 06:47 PM
EddieJones's Avatar
You should be fine using either port for internet with current v1.4.1 software if you are using the internal S6 DHCP Server.
We discovered a rather obvious issue with all EUCON surface setups that used 2 ports on the Workstations a few months back. With Artist it wasn't so much of a problem because most people have the surface on the same network as the internet but with pro consoles where the surface should always be on a separate network it caused lots of issues.
The issue is having a DHCP Server or Router on each network gave the Workstation 2 Default Routes to get to the Internet/WAN/Intranet etc. So the Workstation didn't know which was the right one to use. The solution for S6 was to disable the Default Route in the S6's DHCP Server leaving the real Internet network to supply the correct Default Route to the Workstation. On S5 Hybrid we were able to set static addresses on the Workstations leaving the Default Route blank.
Hope this helps...
Old 04-19-2015, 11:19 PM
Thanks Eddie!
I've plugged it in today with S6 on Ethernet port 1 and Internet Router on port 2 and it seems to be all good so far, so I guess the 1.4.1 update fixed the previous issues. Will let you know if I run into any more problems with it.
Steve Peach
Old 05-20-2015, 08:30 AM
ShadeTek ShadeTek is offline
Default
I would have only one gateway assisgned on your of your NICs or this will confuse your computer. This would mean the manual setting of each NIC with only one NIC with a gateway address for internet access. The other gateway addresses would be left blank.
3 X Z440 W10 32GB RAM, PT 2022.10/2022.4 HDX, 1 X Omni, 3 x X-Mon/S6, 1 X Scarlett Solo, 4 X Blackmagic 4K Extreme, NEXIS E4, Isis 5000, S6 X 3. Synced with Nanosync Word clock.
Old 05-20-2015, 11:02 AM
EddieJones's Avatar
Default
The S6 DHCP does not hand out a Default Route so this is unnecessary if using it.
Ethernet port 2 Frank Kruse Artist Series 23 11-05-2017 02:43 PM
MC Control Ethernet port issue RuffinMedia Artist Series 2 02-03-2011 04:44 PM
No Ethernet port left for the Euphonix mix :( gsilbers Pro Tools TDM Systems (Mac) 7 03-18-2010 07:14 PM
Enable Ethernet Port For Pro Control? RT60 Pro Tools TDM Systems (Mac) 6 10-26-2007 03:32 PM
C24 Ethernet port quit.. please help! Surth ICON & C|24 1 07-22-2006 04:34 PM
