M-Audio O2 as MIDI Controller - Digi 002, PTLE 6.9
M-audio O2 (USB MIDI controller)
OSX 10.4.2 PT LE 6.9.2 Digi 002 I can't seem to set up an O2 as a MIDI device. on MIDI set-up, I click on those arrows of DIGI 002 and O2 but they don't connect. Pls advice. Gerry
- Recording studio Dubbing House in Makati, Phiippines |
Re: M-Audio O2 as MIDI Controller - Digi 002, PTLE 6.9
Not sure why you're clicking on them... If you install the driver for the M-Audio 02, plug it into your usb port, and it shows up in AMS...then it is ready to go. Don't go clicking on any arrows now...just go into Pro Tools, and make sure that it is enabled as a midi input device. Create a midi track, and record enable the track. If the meter activates when you play the O2, then it is hunky dorey. Remember...no arrows ...
G5 Dual 1.8 /1.5 Gb Ram OSX 10.4.7 PT LE 7.3 cs1 DIGI 002 Waves Ren Sony Bundle Soundtoys-arama NI Komplete 3 |
There's no need to connect the O2 with the 002 (both virtually in AMS and with a cable), as the O2 talks MIDI to ProTools / softsynths via the USB connection!
You'll use the MIDI interfaces (and draw lines in AMS) only if using external synth hardware.
Mac mini 2018, i7 3.2 GHz, 32G RAM, 1TB SSD Mojave 10.14.6, PT 2020.5 Vanilla, several Waves V13 and some Massey plugins PreSonus Quantum, Avid S1 & Control, MC Transport, Tascam HS-P82 Field Recorder |
Changing VSTi's in PTLE using midi controller | mal777 | Virtual Instruments | 0 | 06-01-2007 07:35 PM |
Problems with MIDI Controller to PTLE 7 thru USB | AKon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-08-2007 09:55 PM |
Changing VSTi's in PTLE using midi controller | mal777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-08-2007 10:51 PM |
Using Midi Controller For Reason 3.0 in PTLE | cpnraisnuts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 06-02-2005 09:51 AM |
PTLE and Reason Adapted with no midi controller | joesmohello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 10-31-2003 05:45 PM |
