PT HD 11 & 12 on same build?
I'm thinking of installing Pro Tools HD 11.3.2 and 12.4 on the same build - Yosemite 10.10.4. Any caveats with this? Which HD driver do I use? 11.3.2 or 12.4?
Thanks in advance! Scotty D |
Re: PT HD 11 & 12 on same build?
There's some trick in the naming you have to do to get both on the same boot partition as I believe the PT12 installer overwrites the PT11 install. Once you get the solved - as to the driver - I don't know. One possibility is to create a second boot partition and have PT11 on one and PT12 on the other.
Sounds good. I think I'll save my existing 10.8.5 - 11.3.2 setup and do a separate 10.10.4 - 12.4 setup.
THat would work. Hopefully PT11.3.2 is more stable inside Yosemite than 11.3.1 was. I used to have 3 boot partitions (ML, Mavericks, Yosemite) and PT11.3.1 was a nightmare of instability.
New Build Review! Based on Mano/Ame? and SPCR Fanless build | Calipoop | Windows | 4 | 11-16-2011 09:38 PM |
PT just does not work, so should I build a new PC build or just but a MAC? | ajcsound | Windows | 17 | 05-17-2011 10:22 PM |
To build or not to build? Money is the question... | storm-01 | Tips & Tricks | 5 | 09-23-2003 01:08 PM |
To build or not to build? Money is the question... | storm-01 | Pro Tools TDM Systems (Mac) | 12 | 09-19-2003 07:40 PM |
To build or not to build? Money is the question... | storm-01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-18-2003 09:13 PM |
