Old 02-15-2001, 08:34 AM
music_connoisseur music_connoisseur is offline
Default MIDI Output
Okay. I'm a little slow at this. I can get my drum machine to record MIDI information on a MIDI track but now I can't get it back into my drum machine to trigger sounds. I have an aux track set-up to recieve audio out but... is there a something that I have to enable somewhere or is there a problem with the MIDI input on my drum machine?
Old 02-16-2001, 12:03 AM
accession accession is offline
Default Re: MIDI Output
Sounds like ProTools and your drum machine aren't communicating on the same channel. There are 16 channels to choose from for each MIDI port/cable. Each ProTools MIDI track must be assigned a MIDI channel to transmit on. This must correspond with the same MIDI receive channel in your synth/sampler/drum-machine of the instrument you want it to play.
eg.
Ch.1 Siberian Sitar
Ch.2 Transylvanian Harp
Ch.3 Antarctic Flute
N.B. It may very well be that you can only run one drumkit on any one channel at a time. Other synths can run a different instrument on each of its 16 MIDI channels.
Check with your drum-machine's manual to see how to designate a MIDI receive channel for a drumkit.
Now, ProTools must speak the same language. On the left-hand side of the MIDI track, there's an assortment of options/buttons. At the top-right of which, you'll be able to assign which synth you wish it to play. From there, you'll be able to access the channel the MIDI track is to be transmited (tx) on. Make sure this number matches the MIDI receive (rx) channel of your drum machine.
I hope this helps you. Keep us posted with you results.
Phil
Single MIDI Track Output to Multiple MIDI Channels? jb_trm Pro Tools 9 2 07-11-2014 09:09 AM
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 03:33 PM
No MIDI output in PT 9.02 emmen Windows 11 04-23-2011 06:31 PM
MIDI Output Problem - Assigning MIDI Patch Names pancake1975 MIDI 8 05-29-2006 03:25 PM
2 MIDI Input Tracks Output to Same MIDI Channel altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-05-2005 03:20 PM
