  #121
Old 10-16-2018, 07:09 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default HDX Latency
I stopped at 12.8.3 iirc
No upgrades here, I am scheduled to upgrade again in 3 years
Daniel
  #122
Old 10-17-2018, 08:16 AM
Dizzi45Z Dizzi45Z is offline
Default Re: HDX Latency
For me, when tracking, I always make all plugins on master Faders inactive (not just bypassed). I route the outputs of all tracks I am recording on directly to the interface (no busses in-between). I also check the latency of the DSP plugins (by viewing Delay Compensation in the mixer). Some plugins that are AAX DSP introduce too much latency to track with. I try to keep things under 50 samples.
If recording a multimiced instruments (such as drum set), I make sure the latency is the same across all the tracks while recording to avoid phase stuff from being one way while tracking and then different on playback when the ADC is lined up. That often means thst I have the same plugins across all the tracks whether they are being used or not. For me, that is often a channel strip plugin.
Following these rules have rarely ever caused me problems.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Automation latency when using plugins that have long latency pyrodave Pro Tools 11 2 01-27-2014 11:22 AM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
Latency Issues - changing latency has no effect Kippa-Dee Pro Tools M-Powered (Win) 1 07-15-2010 08:39 PM
Piano VI's- Latency Latency!! MARVINBASS Virtual Instruments 5 04-27-2006 01:09 AM
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? Mt.Everest Pro Tools TDM Systems (Mac) 7 08-26-2001 04:53 PM
