#181
Re: We need a Thunderbolt HDX system
Thanks, Darryl. My AVID dealer counsels me that I may not be happy with the tracking latency on HD Native, as I'm used to the latency we've had with the TDM HD system. Apparently HDX offers even less latency than I now have with HD TDM. As for UAD, those plugs are never serially placed on any track at record time, so the UAD adds no latency to what I track. I'm leaning towards a single HDX card and the 3-slot Sonnet chassis which, I am told, offers a quieter fan than the Magma chassis fa. Thanks again, John Caldwell
Pro Tools 2018.4 HDX, 192 and Lucid I/O 5,1 MacPro 12 Core; OSX 10.12.6 |
#182
Now that hardware is unbundled, you could buy an HD Native card, try it out and then replace it with HDX if you have any problems. Input latency is the only difference because 64 bit Pro Tools is dual-buffer. It doesn't work the same way as TDM so the numbers are comparing apples to oranges.
As for sound, HDX plug-ins are more efficient running native than most native-only plug-ins.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
#183
Yes, an idea Bob. I suspect my dealer would accommodate an Native > HDX card exchange.
Did it surprise to read above that some feel the HD Mix Engine sounds different when the HDX cards are in use, vs. the sound of the engine running purely natively on the CPU? The assertion is that the Native-only operation sounds best.
#184
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
#185
Thank you for your insights. John-
Pro Tools 2018.4 HDX, 192 and Lucid I/O 5,1 MacPro 12 Core; OSX 10.12.6 Last edited by Mount Royal; 02-06-2018 at 10:52 AM. |
#186
Yes, because you are avoiding the IO buffer. But the question is how small an IO buffer can you stably track at? And does that additional latency cause a problem or not. And it may not matter if most plugins are AAX-Native... you need to check if the plugins you want to use have AAX-DSP versions, or there are alternatives that do, or not.
Sent from my iPhone using Tapatalk |
Slimming down the PT system. Mac Mini & Thunderbolt peripherals | cheney5 | Post - Surround - Video | 15 | 01-12-2014 03:57 AM |
Looking for someone running an HD Native Thunderbolt system and Waves to compare with | propower | Pro Tools HDX & HD Native Systems (Mac) | 1 | 12-14-2013 12:46 AM |
HD native thunderbolt through Echo Express SE Thunderbolt Chassis | hkj1 | Pro Tools HDX & HD Native Systems (Mac) | 1 | 11-06-2013 05:49 PM |
Until Someone Makes a Thunderbolt Hub, Thunderbolt is a (1/2 Useless) Dead End Street | relaxo | Pro Tools 10 | 7 | 11-12-2012 11:43 AM |
Thunderbolt-Sonnet’s Echo™ Express PCIe 2.0 Expansion Chassis with Thunderbolt™ Ports | Barry Johns | Pro Tools TDM Systems (Mac) | 29 | 08-11-2012 07:01 AM |
