Old 06-23-2012, 04:39 AM
DaniTo DaniTo is offline
Default Eleven Rack Problems with USB e Drivers
Hello guys!
I recently bought this rack.
At first use I plugged headphones and guitar and everything worked perfectly!
As soon as I plugged the USB cable to try to install the driver and use the machine as a sound card ... everything has stopped working.
The headphones will not play any sound.
Everything is off except for some strange sounds in the headphones.
I try to disconnect the usb cable and the problem persists.
The only way to bring things back is to reset the factory settings.
I also tried other usb cable but nothing.
Is there any setting to be changed once you connect the rack or is malfunctioning?
I hope you can help me as soon as possible: (
P. S. I installed the driver apparently correctly, I have set as default for playing sounds but it's completely dead!
Old 06-23-2012, 06:05 PM
Sam C's Avatar
Sam C Sam C is offline
Default Re: Eleven Rack Problems with USB e Drivers
You better call Avid in Italy. I had a problem like that and they had to replace my eleven rack.
Sam
Eleven Rack 1.1.1 Drivers & Mountain Lion MrBig1964 Eleven Rack 0 11-03-2012 08:48 AM
Mountain Lion compatible drivers for 3rd gen Mboxes, Eleven Rack, C400 & C600 Avid Technical Alerts 0 09-25-2012 06:44 PM
How/Where are my eleven rack drivers... leblanc74 Eleven Rack 19 03-31-2011 07:35 PM
Where to find Audio Drivers for Eleven Rack 00011011 Eleven Rack 6 10-12-2010 08:57 PM
Digi 003 Rack problems with drivers wtmd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-28-2008 12:31 PM
