Old 12-05-2009, 07:35 PM
leblanc74 leblanc74 is offline
Default How/Where are my eleven rack drivers...
I want to upgrade to the latest firmware version; however, it shows that I do not have the latest eleven rack drivers installed, I have looked everywhere. Can someone please guide me to where it is...thank you
Old 12-05-2009, 08:14 PM
L-Dogg L-Dogg is offline
Default Re: How/Where are my eleven rack drivers...
I am in the process of doing this. Go to Support> Support and Downloads>ProTools LE select Eleven Rack from dropdown>Downloads>Eleven Rack Update for Pro Tools 8.0.1>scroll all the way down to " Standalone Digidesign CoreAudio Drivers Installer v8.0.1 (Mac)
54.47 MB " or " Standalone Eleven Rack Audio Driver Installer (Windows) "
Hope that helps. Took me a minute also.
Update: Just worked for me! Good luck.
MacBook Pro Retina 2.8GHz i7 (Mid 2014)
16GB Memory
1TB Solid State Drive
Pro Tools 2020.3
Universal Audio Apollo 8P Thunderbolt
Old 12-06-2009, 12:18 AM
thank you for the fast response, I have installed the driver; however, the eleven rack update firmware is still stating that the driver is not installed... I have rebooted the computer a few times and still no show...
Old 12-06-2009, 01:15 AM
Avid's Avatar
Avid Avid is offline
Administrator
What version does your Eleven Rack display? The firmware update and instructions are on this page:
Eleven Rack Firmware Update Version 1.0.1
Updating your Eleven Rack to Firmware Version 1.0.1
Make sure your Eleven Rack unit requires this update by checking the currently installed firmware version number:
* Press and hold the Edit/Back button to access the User Options menu.
* Once the User Options menu appears, use the Scroll wheel to highlight "Firmware Version" and press the SW1 button, which is labeled SELECT.
* If the displayed firmware version is "510", you should run this updater.
* If the displayed firmware version is v 1.0.1 or higher, you do not need to run this updater.
Administrator
Old 12-06-2009, 03:58 AM
reycantong reycantong is offline
Try to check this out:
http://duc.digidesign.com/showthread.php?t=258433
Old 12-06-2009, 07:49 AM
So this is what I am doing...
I have Vista Home NTFS file system and 0510 11R firmware...
turn off my Norton antivirus, everything OK...
Click on Repair for the ElevenRack Driver 1.0.8 (X64), everything OK...
click on eleven rack firmware updater and receive this message..."eleven rack drivers are not installed on your computer. Please download and install the latest drivers and retry this update".
I am trying it with the 11R turned on and turned off... I do not have any issues with the 11R communicating with my computer, I have installed Pro Tools LE and I am able to change the 11R parameters within ProTools...
Old 12-06-2009, 12:23 PM
jjtarnow jjtarnow is offline
Did you do a full re-install of the PT8.01 that came with ElevenRack? It took me a while to figure out that even though I was already running the latest version of PT8.01 I still needed to do a re-install of PT8.01.
Old 12-06-2009, 07:14 PM
I just tried and reinstall everything including a search I did for digi drivers "http://www.paceap.com/dldrvr.html".... still no results... I like the 11R; however, It looks like I cannot bring it up to date. Is there another way I can update the firmware? Please help...
Old 12-07-2009, 01:39 PM
TheChimp's Avatar
TheChimp TheChimp is offline
Are you running Pro Tools while you try to run the Firmware Updater? If so, that might be the problem.
If you're able to launch Pro Tools with Eleven Rack as your ENGINE, then the Drivers are installed and all should be well.
Make sure you quit Pro Tools, then run the Firmware Updater application.
Note that the Driver and the Firmware are two totally different things, and each has its own dedicated Installer. The Driver is on your computer and allows Eleven Rack to talk to Pro Tools and your operating system. The Firmware is in the Eleven Rack hardware, and the only relationship it has to the Driver is that the Driver needs to be on the computer for the Updater to communicate with the Firmware in the hardware.
Best of luck!
_______________________________
The Chimp
Delivery Manager/CSM, Guitar Products/AAX Plug-ins
P&S Creative Professional
AVID
Old 12-07-2009, 06:30 PM
Best of luck!
Thanks for the information,
Protools is closed,
I checked my computer drivers and it clearly shows that digi driver has no issues and it is installed,
I have disabled Norton and all other services that were unnecessary,
I then retried the firmware update and still that same message that I need to install my eleven rack drivers...
is there any have any other advice or something else I can do. This is really disappointing, I really do like the 11R except the fact that I cannot update it...
Why the firmware is not able to see digi's driver from my computer?...
here is the message "The Eleven Rack drivers are not installed on your computer. Please download and install the latest drivers and retry this update."
Eleven Rack 1.1.1 Drivers & Mountain Lion MrBig1964 Eleven Rack 0 11-03-2012 08:48 AM
Mountain Lion compatible drivers for 3rd gen Mboxes, Eleven Rack, C400 & C600 Avid Technical Alerts 0 09-25-2012 06:44 PM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack Problems with USB e Drivers DaniTo Eleven Rack 1 06-23-2012 06:05 PM
Where to find Audio Drivers for Eleven Rack 00011011 Eleven Rack 6 10-12-2010 08:57 PM
