Old 08-29-2009, 03:29 PM
negation negation is offline
Default Peak problem
I'm importing audio (wav, reference material converted with itunes) in to a session and it shows alot of peaking (red light illuminated) goin on. It should not, right? What am I doing wrong?
Itunes can't convert properly?
I use a Mac Pro, HD1 accel, osx 1.5.4.
Thanks.
Old 08-30-2009, 10:54 AM
wolfman_rob wolfman_rob is offline
Default Re: Peak problem
i am having the same problem i would be interested in this also
Old 08-31-2009, 02:23 AM
tj_davies tj_davies is offline
Originally Posted by negation View Post
Thanks.
The red light indicates that you have 3 or 4 continuous samples at 0dBFs. In your case the songs are mastered so loud, that you have long continuous samples hitting 0.
Hope this helps
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 08-31-2009, 02:57 AM
Hope this helps
Timothy
Thanks for the input.
Ok, but I thought that this was a major no-no in the world of pro-audio, I mean to do it deliberately. Does a lot of engineers do this? I for one would NOT!
PT 8.1cs1 HD2 Accel
10.6.4 MacPro 8 Core
Old 08-31-2009, 03:20 AM
Hitting 0dBFs does not necessarily mean it is distorting if that's what you mean by "I thought that this was a major no-no in the world of pro-audio".
Timothy
PT 2020.12.0
Old 08-31-2009, 03:22 AM
woodsdenis woodsdenis is offline
Thanks.
I have found this with commercial drumloops etc aswell as mastered tracks.
I think that PT goes into the red slightly before you reach 0 dbfs, maybe as and extra warning.
DTS can you confirm this
Denis
Mac Pro 3.3 hexacore
24 gb RAM
Lion
PT 10 HD Native
Old 08-31-2009, 10:02 AM
Scott Goldberg Scott Goldberg is offline
If there is peaking in the original session then when you import them, it will show red in the meters for every channel that has peaked at one time or another. As already stated, that's not a problem if you are not distorting but it might be better to record your original tracks a little softer as they will sum anyway and plug-ins will increase gain on whatever channels you feel need a little bump.
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8 hotgravy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-30-2012 10:49 AM
CoreAudio+001+Peak Major Problem Returns... BHeller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-26-2004 10:03 PM
Problem with Bias Peak and Mbox!! isofonico 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-07-2004 08:03 AM
volume/peak/delay indicator problem Zettt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-14-2004 09:24 AM
Mbox peak meter problem. No sound!!!$##$ urban_romantic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-10-2003 08:53 AM
