  #41
Old 09-13-2018, 05:26 PM
arche3's Avatar
arche3 arche3 is offline
Default Re: -9093 stops are killing me!!!!!
Originally Posted by [email protected] View Post
Is everyone super stable in high Sierra?
Yes I am
  #42
Old 09-16-2018, 05:17 AM
Blues Bird Blues Bird is offline
I am on an iMac, High Sierra (10.13.6) PT 2018.7 and those Errors are killing me. Is there any cure that works?
  #43
Old 09-16-2018, 06:41 AM
Originally Posted by Blues Bird View Post
I am on an iMac, High Sierra (10.13.6) PT 2018.7 and those errors are killing me. Is there any cure that works?
move plugins to unused folder, try again. if the stops are gone, you know it is some plugin that causes them.
if it is, then move plugins back one vendor at a time. test again. once stops come back, you know which vendor is at fault.
then move that vendor plugins away once again, moving them back one plugin at a time. once stops come back, you know which plugin it is.
repeat until you have moved all plugins back, par those who give you stops. then contact those plugin vendors and ask what's going on.
  #44
Old 09-17-2018, 02:08 AM
Thank you for your reply.
Unfortunately, I don't believe it has something to do with the plugins. Every time I turn off both the PT edit and the mixing window and control everything with my C24 the session runs smooth - despite of how many and what plugins are working...
  #45
Old 09-17-2018, 09:52 AM
you don't have to believe it. move ALL your plugins to unused folder and continue editing. if there are no stops then, the reason is one (or more) of your plugins
  #46
Old 09-17-2018, 12:06 PM
arche3's Avatar
Usually I blame slate plugins. Lol.
  #47
Old 09-19-2018, 08:12 AM
TOM@METRO's Avatar
Yes. Moving all Slate plug-ins to the unused folder has helped here as well.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #48
Old 10-09-2018, 05:17 PM
[email protected] pqlior@mac.com is offline
Moved most out and same erratic behavior... Also- eleven lite, Maxim, dynamicsIII and most avid plugins keep making their way back to the plugins folder... (while still in the unused folder as well)
Lior
HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 *
iPad Air/Avid control * EuCon 18.3.0.217 *
  #49
Old 10-09-2018, 06:34 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Unfortunately, I don't believe it ...
Without a try [wait] but then a partial try....
Why come here?
  #50
Old 10-10-2018, 04:55 AM
climber climber is offline
^^^ what they said!
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
MIDI Thru stops working after sequence playback stops kelcarpenter MIDI 20 03-16-2016 11:43 AM
11R killing PT thegreyfox Eleven Rack 3 04-24-2012 09:34 PM
This is KILLING me! audiogeekzine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 12-22-2008 04:10 PM
-9093 error's killing me!!! coryc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 10-04-2003 03:24 PM
-9093 Error, CPU stops rec., says buffer problem? storm-01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-16-2003 09:33 PM
